Author Topic: Alarm going ON /OFF - Neighboors want to kill me  (Read 6891 times)
Re: Alarm going ON /OFF - Neighboors want to kill me
« Reply #15 on: 08 June 2009, 23:08:09 »
Hello Matthew
Tks for the reply I will make the same in mine.
I think also this hot weather is making the batteries leaking.
The leaking caused a nice stain in  the PCB and I need make a good recover. It is possible to buy new batteries and because the corrosion in the PCB lost the money and time.
let's see.
San
To prove whether it's the bonnet switch just involves uplugging it. If's not in circuit it can't earth when the bonnet opens/flexes in the sun.
san
  • Chertsey
« Reply #16 on: 09 June 2009, 23:27:34 »
Hello All
Good recover in the powersound PCB, did some joints and put back the leaking batteries for test today.
After install did a test on the alarm and it worked fine, now buy new batteries and put glue/silicon to avoid water.
The LED on the front panel still flashing in the first 10 sec  :-? :-? :-? - Perhaps a new setup or reset (?????????? :-? :-?) Any ideas
Well problem partially sorted. Thanks for all helps and replies.
« Reply #17 on: 09 June 2009, 23:31:44 »
Hello All
Telling you you have a door open or a fault .... and a duff power sounder is probably a fault .... I bet with new batteries it'll work as advertised
Page 61  .....
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Page created in 0.008 seconds with 16 queries.
