Author Topic: SatNav Positioning Issue  (Read 22088 times)
miniator
  • Northern Ireland
    • My YouTube Channel
Re: SatNav Positioning Issue
« Reply #45 on: 18 June 2009, 13:37:17 »
maybe i wasnt giving it long enough to get signal, im not the most patient.
I was gonna run it up to the sunroof motor housing as theres some room in there for it....its up nice and high in the car and out of sight, worth a try again maybe!
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #46 on: 18 June 2009, 13:52:43 »
Don`t shield it from the satellites by placing it under the metal of the roof!
You can put it under plastic and fabric, but not under metal.
Under dash or rear shelf are often favourites - gives it a good unrestricted view upwards
Radio & Decoding Technician
www.dndservices.co.uk
miniator
  • Northern Ireland
« Reply #47 on: 18 June 2009, 14:05:04 »
tried under the dash too, just in with the head unit but couldnt get a signal again.....will try it again although ill lift it up higher in the dash to behind the CID!
Cheers Dave :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #48 on: 18 June 2009, 14:35:22 »
Cheers Dave :)
some areas of dash have metal formers in them, avoid these areas, and not uncommon to wait 20 mins to lock on to a set of satellites if starting from a very "lost" position.
miniator
  • Northern Ireland
« Reply #49 on: 18 June 2009, 14:37:38 »
ok, shouldnt be too hard to find the formers...the aerials magnetic!
....and i definitely didnt wait 20mins lol!, more like 2, thanks dave!
« Reply #50 on: 18 June 2009, 17:25:51 »
From an 'unknown' location, expect 5-20m for a decent fix.  Once fix established, should be fairly quick (assuming you don't remove power to HU)
miniator
  • Northern Ireland
« Reply #51 on: 19 June 2009, 01:27:56 »
tis now located under the dash, behind the CID and working a treat!
thanks guys!!
Pages: 1 2 3 [4]  All   Go Up
