Author Topic: ccr 2006 outputs  (Read 6625 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: ccr 2006 outputs
« Reply #15 on: 19 June 2009, 12:15:09 »
Zirk,
Sorry my friend, didn`t intend to blast off at you there, frustration is kicking in over trying to reply in laymans terms to a problem that really isn`t important to 99.9% of the people, yet I`m waiting for the 0.1% who are going to argue no matter what I respond with.
However . . . . .
You have a cupboard full of DCA800 amps, some MB Quartz speakers, and what promises to be a good weekend ahead of us.
Get them fitted mate !!   :y
Use the lead I have suggested for the RCA conversion, and set the gains on the amps to around 0.4 V - 0.5 V and all should be well.
As far as subs / estate goes, I had a similar problem in my RS4, as I didn`t want to lose valuable space. So what I have done is to fit the amplifiers etc hidden away, but to terminate the sub output on a socket that has been flushed into the rear 1/4 panel trim. That way I can use a seperate sub box and plug it in / out very very quickly whilst keeping all connections nice and tidy. The speaker box connectors and Banana plugs used by most sub boxes are perfect for this.
Radio & Decoding Technician
www.dndservices.co.uk
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #16 on: 19 June 2009, 12:32:55 »
Zirk,
However . . . . .
Well I was thinking about.... (You’re not going to like this!) Adapting a Mig Estate Bose plastic Sub box and replacing the speaker as I’ve got a couple of them lying around somewhere. I’m not really after waking the Nebours or moving people’s inner ear wax, just a nice balanced sub bass to match the rest. Any thoughts on Brands.
Chris.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #17 on: 19 June 2009, 12:46:12 »
Modifying an existing box?
No problems with that at all - sounds a good idea.
Unsure on speaker physical dimensions, but thats easy to determine with a tape measure.
What is more important though, is the volumetric capacity (box size), and finding a speaker that will perform in a similar box.
Not familiar with the box, is it sealed? Ported? are your hacking it about to get something larger in whilst retaining the mounting frame? and pictures?
zirk
  • Epping Forest
« Reply #18 on: 19 June 2009, 13:54:09 »
Dont have any pics at the moment, but there bigger than you would think, about half a meter long, sealed, not ported, with a single Bose Sub, they fit behind the rear panel behind the rear wheel arch, ideally wanting to use the existing mount..
Another plan was to use a Mazda Spare Wheel Bose box and modifing, but you you lose the spare wheel.
Edit:- there was an Mig Sub Box on ebay recently (not mine) so have a butchers here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=350193837476
« Last Edit: 19 June 2009, 13:59:50 by zirk »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #19 on: 19 June 2009, 14:07:50 »
Far from wanting to fit a 32" sub to every car that comes in (I leave that to the lads) I`m more into adding discreet and unobtrusive bass, and I`m sure you could do something with that box.
Looks around a 6" sub from the picture? What is the diagonal measurement across the screws that hold it in? around 160mm ?
zirk
  • Epping Forest
« Reply #20 on: 19 June 2009, 15:09:29 »
No idea, but I'll check this weekend and come back to you. :y
Chris.
