Author Topic: Ignition 12v +  (Read 2551 times)
amba
  • Medway towns
    • German V6
Ignition 12v +
« on: 19 June 2009, 17:05:35 »
Is there an ignition switched 12v+ at the passenger kit panel,that will provide power with key in position 1 and ignition on.
I cannot pull out radio as cage is jammed solid,so need an extra feed wire for accessory,but not permenant 12v,just switched.
Re: Ignition 12v +
« Reply #1 on: 19 June 2009, 17:07:50 »
I think W contact is down there (12v at I, II, and at 0 if the ign has been switched to I and the key hasn't yet been removed).
You'll need to look at the wiring diags to see which on it is though!
amba
  • Medway towns
    • German V6
Re: Ignition 12v +
« Reply #2 on: 19 June 2009, 17:10:19 »
Thanks TB.....don,t suppose any idea on colour of wire as I had a good poke around and can only find permenant 12v+ .
Re: Ignition 12v +
« Reply #3 on: 20 June 2009, 11:03:34 »
Pin 12 on connector X1. Red.
amba
  • Medway towns
    • German V6
Re: Ignition 12v +
« Reply #4 on: 20 June 2009, 11:06:48 »
TB...thanks alot...and that is accessable at the passenger kit panel ?
amba
  • Medway towns
    • German V6
Re: Ignition 12v +
« Reply #5 on: 20 June 2009, 11:15:03 »
Haynes wiring is next to useless...states..".X1.wiring connections"....and thats it,no further details.??and you need a magnifying glass to see the schemetics,so totally useless imho.
Re: Ignition 12v +
« Reply #6 on: 20 June 2009, 11:15:30 »
the x1 connector is behind passenger kick panel.  Not the easiest to connect to.
