Author Topic: Can someone confirm a couple of things please  (Read 19162 times)
littleimp
« on: 30 May 2009, 12:09:29 »
1. The foglight switches----The front one of mine clicks in and out and works fine. The rear doesn't click and everythings ok as long as I hold my finger on the button but doesn't stay on when letting go. Is the rear switch click like the front??
2. Cruise control----- Was driving down a main road so I though I'd try the cruise control. Nothing, not a beep, light, click or murmur. Does a light come on with this? Any common faults on these?
Have to say I'm loving the car though, a joy to drive and comfy too.
nick v6
  • walsall / west midlands
Re: Can someone confirm a couple of things please
« Reply #1 on: 30 May 2009, 12:35:50 »
fog light switchs - yes they do click, if you have to hold your finger on the switch to make it stay on then the switch is at fault
cruise control - no lights or beeps, best thing to do is get on the motorway or dual carriage way hit 60mph and hit the cruise control button it should keep it at that speed if you come to a hill you should feel the car pick up to keep the speed the same
hope that helps you out :y
littleimp
« Reply #2 on: 30 May 2009, 12:46:06 »
Can you confirm both switches click?
I'll give the cruise control a try at a higher speed.
Cheers
nick v6
« Reply #3 on: 30 May 2009, 12:49:24 »
Cheers
the cruise control should work over 19mph if i remember right
i'm pretty sure both buttons click
i can't try mine as mine is still in the garage after the accident
ill get it back on monday, but i am pretty sure they both click
something to try
take out both switchs for front and rear fogs if the connectors are the same swop them over and try that
only need a small screw driver behind the switch to pop them out :y
let me know how you get on
Ziad
  • Bahrain
« Reply #4 on: 30 May 2009, 13:27:25 »
I confirm that both switches click when switching on or off the front / rear fog lamps. One of mine (front one) was not clicking and the fog lamps did not come on at all. I changed the switch and now it's fine. Note that the switch come in pairs. If one is not working, you need to change BOTH of them as the switches are ONE UNIT.
littleimp
« Reply #5 on: 30 May 2009, 17:31:10 »
Have now fixed the fog light switch. An easy diy repair to be honest.
1. Lever out switch panel
2. Lever out fog light switches from switch panel
3. Lever off the switch button cap and remove the 2 x long springs. You will then see a white frame inside the switch with some clear plastic that provides the 'on' light.
4.Pull out sqaure clear plastic and the frame will lift and you can remove. At the end of the frame is a v cut in that accutaes on a lever that provides the clicking action. Inside the switch you will see a tiny spring lever that runs through this v channel.
The fault is the V channel. The end of the 'V' is slightly rounded off. I gently applied a hot scalpel to 're-shape' the end of the v so the runner would go into the right side of the channel.
Put it back together and it workd perfectly.
An easy job and a good tip if you have a similar fault.
« Last Edit: 30 May 2009, 17:32:22 by littleimp »
nick v6
« Reply #6 on: 30 May 2009, 17:37:12 »
well done mate a good self fix :y
Phil
« Reply #7 on: 01 June 2009, 21:30:54 »
When you 'engage' cruise you should fell the accelerator pedal move 'down' slightly
Well it does in mine  ;D
« Last Edit: 01 June 2009, 21:31:54 by Phil »
« Reply #8 on: 01 June 2009, 21:35:34 »
yup, does it on all non DBW cars :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #9 on: 03 June 2009, 19:25:37 »
Except mine [smiley=rolleyes.gif]
Trade club card holder
Code scanner available
« Reply #10 on: 03 June 2009, 19:44:15 »
your 2.2 is dbw...
alexandjen
  • The Silver Surfer
« Reply #11 on: 03 June 2009, 19:49:18 »
your 2.2 is dbw...
I know, but it hasn't worked for nearly a year, don't know what's up with it. I've changed the stalk but still doesn't work :(
« Reply #12 on: 03 June 2009, 19:53:04 »
your 2.2 is dbw...
if ever you make it up north to northamptonshire.......
alexandjen
  • The Silver Surfer
« Reply #13 on: 03 June 2009, 19:59:37 »
your 2.2 is dbw...
Yeh thanks TB, I keep meaning to get over to Kevins for a diag (assuming he's still got the Tech II), or if he ventures into Kent for gliding he said he might be able to take a look :)
littleimp
« Reply #14 on: 04 June 2009, 14:32:45 »
Can now confirm cruise control is working. Pressing the on button didn't seem to do much but pressing the I button after the on button seems to activate it.
