Author Topic: anybody knows what this wire is for???  (Read 9582 times)
mathewst
  • Split, Croatia
    • v40
« on: 18 June 2009, 21:49:18 »
In the lower left corner the wire above  40 amp fuse.
What the hell is this for? Looks like something short circuited intentionately.
This was in the car when I bought it. I'm really interested what it's for.
http://img195.imageshack.us/gal.php?g=dsc06298b.jpg
http://yfrog.com/5fdsc06298bjx
Agemo
  • Cleethorpes
  • Insignia
Re: anybody knows what this wire is for???
« Reply #1 on: 18 June 2009, 22:22:25 »
Just had a look at my fusebox, I don't even have any connections in that position. I have heard of wires being fitted like that, some sort of by-pass. Is your car ex Diplomatic protection or something? What does that label say?
« Last Edit: 18 June 2009, 22:23:05 by Agemo »
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 18 June 2009, 22:25:30 »
Diplomatic nope!
Just some numbers and things like that on the label but will check tomorrow
shammster
  • Essex, UK
« Reply #3 on: 18 June 2009, 22:26:41 »
Could that be the link wire to enable the brake light feed for the towbar plug?
Someone mentioned it in another thread but I don't know if thats where it goes.
So many cars to fix, oh well open the beer!
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 18 June 2009, 22:37:37 »
Dont think its that link cause car doesn't have a towbar fitted
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #5 on: 18 June 2009, 22:37:47 »
I think that's behind the glove box
Trade club card holder
Code scanner available
shammster
  • Essex, UK
« Reply #6 on: 18 June 2009, 22:39:21 »
Don't know then, book of lies in garage with car, and to lazy to fetch.
« Reply #7 on: 18 June 2009, 23:29:15 »
Above/behind the glove box on facelift cars
Above the driver's feet on prefacelift car ..... it took me ages to find it!  :-?  ;)  ;)
mathewst
  • Split, Croatia
    • v40
« Reply #8 on: 19 June 2009, 07:47:57 »
Andy if you think that this wire is for towbar there is only one problem.
Car is facelift
« Reply #9 on: 19 June 2009, 10:24:39 »
Car is facelift
No Matt, your wire is completely seperate from the towbar wiring bodge/bridge.
Is there power on it? I'd remove it and see what difference it makes, it shouldn't be there in the first place and presumably someone in the past has been trying to bodge something.
mathewst
  • Split, Croatia
    • v40
« Reply #10 on: 19 June 2009, 10:30:58 »
Havent tested it for power.
Not sure if I want to remove it before having a vague idea what its for
« Reply #11 on: 19 June 2009, 14:44:49 »
That looks like a 6 pin connector with a couple of pins bridged. :-/
Initially worried that some muppet had bypassed a fuse that kept blowing but that doesn't appear to be the case. My guess is that it it's a diagnostic connector or a space where some piece of optional equipment would be connected. Not sure what, though.
« Reply #12 on: 19 June 2009, 14:53:42 »
I've just looked at my car, there's just an empty square hole  :-?. I'd be haing a look behind the drop down fuse carrier/box and see where the wires come/go from/to.  :y Does it look like someone had a spare roll of cable?  ;) Or does it join into the proper loom & appear to be original?
mathewst
  • Split, Croatia
    • v40
« Reply #13 on: 19 June 2009, 15:05:22 »
Well it seems to be original.
And the writing on the plastic cover of the fuse box says that it it the place for optional equipmnet as I recall
« Reply #14 on: 19 June 2009, 15:17:50 »
I think you need to try to find out what your 'optional equipment' is then  :-/, even the handbook book shows a space  :-/http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf  Page 185/6
