Author Topic: anybody knows what this wire is for???  (Read 9587 times)
mathewst
  • Split, Croatia
    • v40
Re: anybody knows what this wire is for???
« Reply #15 on: 19 June 2009, 16:06:27 »
Wlee checked the paper on the wire and here are samo information from it
7Q    Delphi
90 505 470 (guess this could be eventually some part number if anyone can confirm))
And on the cover of the fuse box it says "Varianten kodierung"
Hope someone now can be able to solve the mystery
kris
  • manchester
« Reply #16 on: 19 June 2009, 19:13:48 »
7Q    Delphi
And on the cover of the fuse box it says "Varianten kodierung"Hope someone now can be able to solve the mystery
loosley translates into variants encoding.
have checked the fuse box on my 2000 elite and i've only got an empty space.
pull the wire out and see what happens
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #17 on: 21 June 2009, 20:43:17 »
I've got it also and I'm quite sure it's for the "headlight memory": it turns on the headlights automatically when starting. The feature was only fitted to Belgium-spec cars AFAIK, used mainly in Scandinavian countries, apparently also in Croatia
