Author Topic: aftermarket headunit with elite bose sound system  (Read 2359 times)
elitekev
  • poole
« on: 24 June 2009, 17:46:59 »
is there a loom or easy way to get my jvc kv-adx1 headunit to work with the elites bose system? at the moment it has the ccrt700 in, put my headunit in and got no sound using the iso plug with the 2 plug ends on(3x plugs on car loom), can anyone help me with this?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: aftermarket headunit with elite bose sound system
« Reply #1 on: 24 June 2009, 17:49:32 »
Sorry, the JVC system is not compatable with the BOSE system. You will also need to replace the speakers as well, as the 2 Ohm BOSE ones will blow the JVC to bits should you opt for the preferred route of bypassing the BOSE amp.
Its failry well documented on here if you look through previous posts.
Radio & Decoding Technician
www.dndservices.co.uk
elitekev
  • poole
« Reply #2 on: 24 June 2009, 17:57:47 »
can someone please recomend a unit that is then please?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 24 June 2009, 18:06:20 »
Only the Original BOSE head unit will work with the BOSE system, if you want to replace any part of the BOSE system, then it will have to be removed in its entirety, amp, wiring, head and speakers as none of it is designed to work with anything other than the BOSE system that Vx put in there from day 1.
elitekev
  • poole
« Reply #4 on: 24 June 2009, 18:21:26 »
cheers dave, was hoping for ipod connection lol, i suppose i could get one of those cassete adaptors that peole used for personal cd players etc and run the ipod that way?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 24 June 2009, 20:08:34 »
I`d suggest going down this route to play the iPod
http://www.dndservices.co.uk/am-88t.html
