Author Topic: philips sc804cdc radio stuck on SAFE mode  (Read 4699 times)
helen
« on: 26 June 2009, 12:43:50 »
Hi there, i have a 1994 omega elite, it has a philips sc804 cdc and i recharged the battery and put it back then checked and cleaned the fuses because i had some other leccy problems, the radio needed codeing in which i have a done before but this time it only showed SAFE and no numbers, i tried a couple of times but still came up SAFE. any help would be appreciated, thankyou, peter, helens other half. ps as i said i have the right code and also the 14 digit s/n, thanks again.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: philips sc804cdc radio stuck on SAFE mode
« Reply #1 on: 26 June 2009, 12:50:12 »
SAFE with no numbers is forgetting to turn the ignition on first !!
Code Entry as Follows:
Switch On Ignition (No Need To Start Engine)
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
And the Radio will then Turn On
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #2 on: 26 June 2009, 12:51:19 »
You may have forgotten Helen that you need to have the radio off, turn the ignition on, then whilst holding the 'AS' button in turn the radio on, then you can enter your code via buttons 1-4. ;) ;)
« Last Edit: 26 June 2009, 12:51:37 by Lizzie_Zoom »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 26 June 2009, 12:57:14 »
Oops! I forgot to say press and hold AS whilst turning it on
helen
« Reply #4 on: 26 June 2009, 13:19:26 »
Hi again, iv'e tried these sequencies  ie: ignition on, radio off, push AS then turn radio on at the same time, the SAFE comes up and then nothing else just SAFE, only.????
helen
« Reply #5 on: 26 June 2009, 13:22:58 »
PPS, my radio can be swiched on without the iggy being on in normal use. peter
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 26 June 2009, 13:29:48 »
Yes, the Vx stereo can be turned on normally without the ignition, but the code can ONLY be entered with the ignition switched on first.
SAFE with no numbers shown means that the radio has not seen the igntion switched on
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 26 June 2009, 13:30:47 »
Remember to press and HOLD the AS button whilst turning on, give it a good ten seconds or so.
helen
« Reply #8 on: 26 June 2009, 18:05:27 »
Hi DAVE DND, when i've done that sequence the SAFEcomes on as you said but then i do'nt get the 10 ---- come up, just the word SAFE.??? thanks peter.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 26 June 2009, 18:57:32 »
Then its time to get the meter out and measure the permenent and switched supplies at the back of the head unit, as it would appear as if one of them is missing
