Author Topic: Removal of the automatic lights thingie  (Read 9975 times)
Joh
  • Estonia
  • Passive
« on: 27 July 2008, 19:39:43 »
Hi guys,
would anyone be so kind and tell me if there's a way to remove the system that turns on the lights automatically? I mean like removing some relay or anything?
Thanks in advance,
Joh from Estonia ;)
Opel Omega B 2.0 ECOTEC 100KW (1996)
Bandit127
Re: Removal of the automatic lights thingie
« Reply #1 on: 27 July 2008, 19:50:00 »
I don't know what the answer is, but I suspect it's got 'Tech 2' in it.
Joh
  • Estonia
  • Passive
« Reply #2 on: 27 July 2008, 19:56:24 »
What does that mean, mate?
-edit-
Alright, it seems it's somekind of a tool of diagnostics. Can you reprogram your car's "brain" (the right word doesn't come to my mind at the moment as English isn't my native language)? I'm still hoping I could do that just by removing somekind of a relay or a fuse or something like that :P Or by cutting some wire or something..
« Last Edit: 27 July 2008, 20:05:16 by joh »
Bandit127
« Reply #3 on: 27 July 2008, 20:20:42 »
It seems that most of the options (like daytime running lights) have been programmed from the CPU on this car. Tech 2 is the system used to reprogramme these options. Tech 2 costs at least £40 (€50) to get it out of its box in this country.
I do not know the answer to your problem, sorry. I hope that it is as easy as removing a relay, like it is for older cars. Maybe someone who does know will be along soon.
Your English is great by the way.  :)
Taxi_Driver
« Reply #4 on: 27 July 2008, 20:50:50 »
Which lights do you mean?
I dont know of any Omega that turns its headlights on automatically....... :-/
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #5 on: 27 July 2008, 21:00:49 »
Do you mean the sidelights while ignition is on??
There is a fuse in the fusebox specifically for it. I think its Fuse 8...
Humbugs...
Joh
  • Estonia
  • Passive
« Reply #6 on: 28 July 2008, 00:11:45 »
First I gotta say thanks :P
But now I'm really confused.. You people are saying that when you start drivin' you have to do something so that the lights would be on? I don't! When I start my engine - lights are on.
Do you guys have to turn the round button (or whatever) to turn on any kind of lights (again I'm not sure how they are called in English.. I mean the regular lights you use when you drive in regular conditions)? As I don't have to change anything. When I leave the button (?) or switch (?) in the same state they are in the shown picture (did you click on the link already :P?), the lights are on. And I just installed xenon lights to my Omega and I have heard that turning on your xenons too often is the only factor that causes your lights to wear off.. (damn, that sentence doesn't look like proper English at all :P).. anyway so I thought that when I'm driving at the nighttime, I first turn on the engine (and the lights also turn on), then I turn the switch shown on the picture, so that I could see what my speed-o-meter and tachnometer (again I don't know how should I call the whole thing together... clocks? the speed-o-meter block? whatever, right) are showing... when the switch is sat on 0-state, only the headlights and parking lights are working.. when I turn it to the IIIrd position, all the lights inside the car also start to glow (positive factor at night :P).. soo..... I start the engine, xenons are on, I turn the switch - xenons fade/die/what_the_opps_ever for a sec and then they turn on again (and that's supposed to kill them in the longer perspective)... so if I could somehow turn of the automatic thing, I would save my xenons.. Lol that was some long text, I have drank couple of beers tonight also so that wasn't so easy to compie all that text :P Anyway, I hope I made clear all my thoughts.. And really, no Omega has automatic headlights? Damn, then it should be as easy as removing someone's personal modification or what?
Anyway,
Thanks in advance, all of you ;)
Joh
« Reply #7 on: 28 July 2008, 06:28:34 »
When our light switch is in the position as shown in your link, we have no lights on at all, anywhere. When we turn the switch to the middle position, we get side lights ie the small 5 Watt lamps inside the inner main beam reflector. Turned fully to the right lights up our outer dipped beam & obviously the indictor stalk switches between just dipped or main beam too.
Pulling the switch, will turn on our front interior courtesy light.
The whole speedometer & tachomter ..... Yes, clocks is OK If you wanted to be really posh you could call it a binacle  ;)
Turning your xenons on & off too many times might wear them out.  ;)
Joh
  • Estonia
  • Passive
« Reply #8 on: 28 July 2008, 09:45:28 »
Ha, thanks for the English tips ;) Anyway, I tried to get help from an Estonian Omega forum also and it seems that everyone in Estonia also have automatic lights. I guess you people live in GB, right? Then I just think that Omegas that have been released under the Vauxhall trademark might be a little different (not to mention your steering wheel is on the right side :P).. I even almost got the answer to my question, the relay should be somewhere under some plastic near the passanger's seat. And I suppose there might be a chance for you to turn that function ON by connecting something to something in there :P though I dunno if that's what anyone wants.. Anyway, thanks for being so helpful and all..
Cheers ;)
« Reply #9 on: 28 July 2008, 09:57:09 »
Ha, thanks for the English tips ;)  ......
It doesn't appear that you need many tips on the English language. Your English  is very good.  :y  :y  :y
We tend to be very lazy over here. The rest of the world learns English from a very young age so we often don't bother to learn another language.
« Reply #10 on: 28 July 2008, 09:58:10 »
Your car possibly supplied for Swedish market - running lights on with ignition is legal requirement there.
« Reply #11 on: 28 July 2008, 11:44:59 »
Its normally a case of pulling out K59 which is the daylight running relay
MV6Man
  • Finland
« Reply #12 on: 28 July 2008, 13:24:34 »
If you remove fuse 8, it should disable that.
Joh
  • Estonia
  • Passive
« Reply #13 on: 28 July 2008, 16:33:40 »
The first owner of my car was a leasing company in Estonia. Maybe my car is just from the same patch that was meant for Swedish market.. But I'm trying to find out, how large part of Estonian Omegaowners have that function included.. I'll let you know :)
Yeap, but would removing that fuse allow my side lights to work when the lights switch is in position II and III?
Anyway, all in all.. I think it's either the K59 relay or the 8th fuse. Therefore I think my problem is solved now and I gotta thank you all for your help. I registered here because of that problem but I'm not going to leave anymore, hehe :) I like it here!
Yeap, that's how it tends to be with larger nations. If I pick a random direction and drive 300km from my current location, I can be 99% sure noone would understand Estonian there ;) And I can be quite happy that I have had the chance to learn many different languages, including English, Swedish, Russian, German and even Latin ;) I'm not saying I can communicate in all of 'em, but atleast I can analyze different languages thanks to what I know, and of course to some point I can communicate with people in their native language, which people do respect, according to my experience ;)
Alright, have a great week ;)
« Last Edit: 28 July 2008, 16:35:28 by joh »
MV6Man
  • Finland
« Reply #14 on: 28 July 2008, 18:22:16 »
If you remove that fuse 8, it should just cut  power to that relay, everything else should work correctly.
