Author Topic: Gearbox limp mode  (Read 1730 times)
KillerWatt
Gearbox limp mode
« on: 06 July 2009, 08:45:26 »
As per the title, gearbox randomly goes in to limp mode.
Car is a 3 litre MV6 on an X plate, Kevin has done a Tech 2 and given me the following codes:
P1625: Power Control Final Stage - Low Input
P1850: Shift Solenoid C - Circuit Open
P1850: Shift Solenoid C - Low Input
This is a random fault that occurs whenever it feels like it once the car has warmed up, and can be "cured" by stopping the car & restarting.
Now I agree with Kevin that the first things to check are the wiring & connectors associated with the gearbox & the ECU, but does anybody know the rough locations for any plugs/connectors involved?
About the only other thing I know is that the car has very recently had new front pipes/cat's, although the owner cannot remember if the fault was present before these were changed.
Are there any plugs/connectors nearby that could have been dislodged when the front pipes were fitted?
    • 530D M Sport, 330i Coupe
Re: Gearbox limp mode
« Reply #1 on: 06 July 2009, 08:56:35 »
Connector on the top side of the sump.
KillerWatt
« Reply #2 on: 08 July 2009, 08:08:58 »
Thanks  :y
Page created in 0.188 seconds with 20 queries.
