Author Topic: Bl***y alarm!  (Read 2180 times)
bazzer
Bl***y alarm!
« on: 08 July 2009, 21:25:57 »
Thinking caps on everyone :-?. Thought my problem was fixed when I put new power sounder on. Now car alarm has activated when I used fob to unlock doors. I couldn't stop it at all :o. Must have continued for about a minute. Half way through, it decided to change tempo and added a warble to it. Tried opening and closing doors, using fob to arm and disarm alarm, turned ignition on and off. Then it silenced. So...yet again I am back to square one me thinks. Any suggestions????....Pleeeease!! :'( :y
Cheers...Bazzer
« Last Edit: 08 July 2009, 23:42:44 by bazzer »
unlucky alf
  • worksop, notts
Re: Now alarm activating using fob to unlock door!
« Reply #1 on: 08 July 2009, 23:29:59 »
im wondering if its because the batteries in it havent had a chance to fully charge yet, its only a guess though :-/
bazzer
« Reply #2 on: 08 July 2009, 23:40:28 »
Been okay since last Saturday. Just had to disconnect as now constantly sounding. No fun in the pitch black with just a wind up torch to illuminate! ::) I'm wondering if it has anything to do with voltage drop? Any idea's?
unlucky alf
  • worksop, notts
Re: Bl***y alarm!
« Reply #3 on: 09 July 2009, 14:52:29 »
you havent by any chance fitted an after market stereo?, i had a problem with my alarm going off for no apparent reason, but since using another aftermarket stereo[jvc] my alarm has been fine, i know about swapping the 2 live wires over but when i wired up the first stereo correctly [medion] it flattened my battery :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Bl***y alarm!
« Reply #4 on: 09 July 2009, 15:58:47 »
Quite a common problem with Cheesy Chinese radios - can only advise to pay more than 50p for your stereo, stick to a well known brand, and all should be well
 :P
Radio & Decoding Technician
www.dndservices.co.uk
bazzer
Re: Bl***y alarm!
« Reply #5 on: 09 July 2009, 16:23:02 »
Bog standard factory fitted unit (if memory serves me correctly I think its a CR700 unit). Been told that Power Sounder has to be programmed into alarm system. Does anyone know if this is a ignition on/off pressing fob in a sequence kind of diy job, or is this a dealer only loadsa money job? Not sure if worth spending more, but waste of money buying Power Sounder if I don't :-/
« Last Edit: 09 July 2009, 20:05:28 by bazzer »
