Author Topic: NCDR1500 fitted and working  (Read 41353 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDR1500 fitted and working
« Reply #15 on: 08 October 2008, 23:57:57 »
Very impressed  ;)
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #16 on: 09 October 2008, 08:23:08 »
I'm in love with the display... it's so tidy!
Just wait until the CID is fitted  :y
Once I've you've fixed it ;D
I have a theory about getting the NCDR pairing code as well...  ::)
Drop me a PM  :y
« Reply #17 on: 09 October 2008, 08:54:54 »
Drop me a PM  :y
Said theory on hold after a chat with a certain member who knows more about such things than I do  :'(
« Reply #18 on: 09 October 2008, 09:17:03 »
Drop me a PM  :y
Tempted to read the prom for an unpaired unit, then pair it with a knwon code and then do a hex comapre of the files to see where the differences are....this should give location of the code in memory (and format although I suspect it might just be HEX).
Should then have the ability to examine a coded unit and identify the code
« Reply #19 on: 09 October 2008, 09:36:29 »
Drop me a PM  :y
That was going to be my method, but monitoring the CDC board.  Seems I may be barking up wrong tree though, guess I'll have to do similar in headunit or display, but display scares me, and I suspect its held in a microcontroller in head unit, so probably getting a little out of my depth  :'(
I have be told a few bits by an active, knowledgable member in this section, but will not pass on specifics - not that many people here would have the capabilities anyway.
Your particular issue, Marks DTM, is I guess simply getting a depaired 2013 and depaired CID (and possibly a depaired CDC3, but this may not be required??) onto your paired 2013 and probably paired CID?  Obviously, that would leave your GID useless.  I have a depaired 2013 and depaired CID, and if I can get into Mother Tunnie's car (::)), possible something with related to a CDC3 board.
« Reply #20 on: 09 October 2008, 09:37:41 »
Drop me a PM  :y
Might be better to pair with known code, read prom, pair with a different known code, and read again to compare?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #21 on: 09 October 2008, 09:48:39 »
Correct on all counts - info is NOT stored on CDC3 but on head unit itself. Absolute Ba**ard to  interrogate, and if you find an easy way to do it, please let us know !!
« Reply #22 on: 09 October 2008, 10:09:49 »
What about reading code from display - is that easier?  Once we can work out what the code is, I can depair via tech2 - which is the ideal solution, as it overcomes the uncertainty around the telematics :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #23 on: 09 October 2008, 10:13:21 »
PM sent    :y
« Reply #24 on: 09 October 2008, 10:49:42 »
[split] [link=http://www.omegaowners.com/forum/YaBB.pl?num=1223544723][splithere][/link][splithere_end]
« Reply #25 on: 22 October 2008, 21:20:25 »
Which it now is :D
    • 530D M Sport, 330i Coupe
« Reply #26 on: 22 October 2008, 21:29:24 »
Which it now is :D
Wahey! Makes the NCDR far more useable, not least with the full Nav map display.
« Last Edit: 22 October 2008, 21:34:32 by VXL_V6 »
« Reply #27 on: 22 October 2008, 21:50:36 »
Which it now is :D
I'm not convinced I don't prefer the GID if I'm honest.
Things I like about the CID - the clock is ALWAYS displayed (approaching junctions, clock o=not displayed on GID), and that the pictorial satnav screen shows distance to destination without delving into menus.
The pop-up map of complex junctions is handy on CID as well.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #28 on: 22 October 2008, 22:01:28 »
fair play!!!!!!!!!!!!!
« Reply #29 on: 24 October 2008, 00:06:34 »
If anyone is that interested, I will do a short video showing it in action, as I know the NCDx setup will be unfamiliar to many.
Video time then? I have to say, thats bloody impressive Jamie. Having seen, or got a bit of an idea more likely, of what you had to go through to pair the cid to head unit i am amazed. I posted pics thinking you would never crack it, i am sorry i doubted you. Fair play indeed...
I reckon you might be ready to convert a cid to work with tv out on n95 now then? I have not given up on that "little mod"... ::)
