Author Topic: REAR BLIND FITTING  (Read 4514 times)
neilr
  • Barnet, Herts
REAR BLIND FITTING
« on: 21 July 2009, 17:53:34 »
hi does any one know how hard it os to fit above to a cd model 2001 i had one in the cdx and found it useful for keeping the car cooler
Re: REAR BLIND FITTING
« Reply #1 on: 21 July 2009, 18:40:01 »
Remove parcel without blind. Refit parcel shelf with blind, plug it in & fit switch ..... so they say! ;)
I've removed my shelf/blind ages ago, & the only problem was a bit of stray rear screen glue was holding he shelf in too. It gave in in the end!  ;D ;D ;D :y
Beverley
« Reply #2 on: 21 July 2009, 18:50:46 »
yours should have the wiring already to be honest and is just a case of out with the old and in with the new and connnect the wiring..
Dont forget to get the switch in the dash to work it though
Bev
« Last Edit: 21 July 2009, 18:51:02 by Beverley »
AndyVXR300
« Reply #3 on: 21 July 2009, 19:10:31 »
Bev
Spot on Bev
You must of been watching me do mine :D
WWW.VXRONLINE.CO.UK
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #4 on: 21 July 2009, 19:26:11 »
I've fitted one to my CDX -  only couple of little problems were that the wiring plug connector was different as the blind came from a pre-facelift and the slot for the seat belt cover needed adapting slightly so that the trim piece clipped in properly :y
Wiring should be up under shelf in boot on left hand side :y
As said, get the dash switch (about £10 from Vx) which is plug and play :y
Other than that it was pretty straight forward, the guide below helped me....................
http://www.omegaowners.com/forum/YaBB.pl?num=1152745304
Trade club card holder
Code scanner available
neilr
  • Barnet, Herts
« Reply #5 on: 22 July 2009, 14:58:03 »
thanks guys anyone breaking a facelift with a blind ?
