Author Topic: Fixing the ballast for xenon lights  (Read 2065 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 24 July 2009, 14:42:19 »
Just wondering as I haven't had a chance to look yet.
But how exactly do you fix on ballast units to the underside of the xenon lamps.
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: Fixing the ballast for xenon lights
« Reply #1 on: 25 July 2009, 20:01:10 »
They fix on with a bracket and are held in place by 1 small torqs screw. Diiferent bracket for each side, drivers is more or less in line for the screw and fitting point, passengers is out of line. A bit vauge I know but if you have/get the brakets you will see. If you are really stuck or are planning on making them yourself I can photo mine for you.
Al
If it aint broken, you aint trying hard enough
