Author Topic: MoT - Lights  (Read 2976 times)
zulu one zero
  • Aberdeen
MoT - Lights
« on: 31 July 2009, 09:55:21 »
Hi guys, had "the great white" in for an MoT yesterday, (i have a wee deal going, in that i put it in, they MoT it, & just tell me what needs doing) I knew the exhaust needed replacing from the cats back - done, & they've decided the brake lines need replacing. Pretty fair really as it hasn't been properly used recently, due to my being out of the country a lot.
However, they have pointed out an issue with my xenons (standard police fit). The level is fine, & suddenly started to move up & down, & repeated this a few times. I must admit I haven't really noticed this, although as I write this, I do recall the level light on the dash flickering on & off every now and then. Does anyone have any ideas what could be the cause of this. Or do I need to get hooked up to a box of tricks to find out what the prob is?
Any help would be very much appreciated!!
 8-)
Re: MoT - Lights
« Reply #1 on: 31 July 2009, 10:43:20 »
Which level light is that?  :-/ :-/
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: MoT - Lights
« Reply #2 on: 31 July 2009, 11:13:38 »
Loose or sticking sensor? Maybe?
zulu one zero
  • Aberdeen
Re: MoT - Lights
« Reply #3 on: 31 July 2009, 11:21:58 »
it has a dipped beam pic, with arrows pointing up, & down. in the central info display. looked at it in the dark last night, when parked up. the lights are definitely moving up & down on their own!
mathewst
  • Split, Croatia
    • v40
Re: MoT - Lights
« Reply #4 on: 31 July 2009, 12:44:06 »
Well probably looks either thr front or back sensor is playing with the signal. Check them visually
zulu one zero
  • Aberdeen
Re: MoT - Lights
« Reply #5 on: 31 July 2009, 14:20:11 »
I think I know where the relevant sensors are, but, for the avoidance of doubt, can anyone tell me exactly where they are, and what exactly I'm looking for/what do they look like? As far as I'm aware, there is one at front, on rear, both on same side, and if I remember correctly, they are on the near-side??
Thanks folks
Re: MoT - Lights
« Reply #6 on: 31 July 2009, 14:34:34 »
Thanks folks
Correct!
A little box of electrickery with a small link arm attaching the box to the wishbone at the front and the radius arm at the rear.  :y
zulu one zero
  • Aberdeen
Re: MoT - Lights
« Reply #7 on: 31 July 2009, 23:03:22 »
next question - how do I know which one is dodgy? can tech 2 tell me, or is it easy enough to tell? Also, how easy is it to replace?
Re: MoT - Lights
« Reply #8 on: 31 July 2009, 23:15:09 »
Tech II is able o tell you which one. They're easy to change although Vx have recently doubled the price to around £100 each!  :-?
