Author Topic: Heated seat elements ........  (Read 5961 times)
I_want_an_Omega
« on: 28 July 2009, 18:40:21 »
Is it usual for the rear or base elements of the heated front seats to go?
I've got a pair of non-working heated front seats in one car, and only one in my donor car. Both are S reg.
Does anyone know if the heating elements in the rear seats are the same as the fronts? Its just that as I've got a heated rear seat  - I see that as possible source of parts for the repair.
Does anyone know if the heating pads are expensive from a dealer?
Thanks ........ Rob
Re: Heated seat elements ........
« Reply #1 on: 28 July 2009, 19:00:57 »
Pretty common fault I'm afraid. The base & lower back are wired in series with each other so that's why you lose heat in both when one fails. If you've got leather the mats are integral to the leathr cover so cost an arm & a leg if you go to Vauxhall as they'll want to sell you the lot!  :-?  It's possible I believeto fit seperate mats form fabric seats under the leather cover. There's a how-to-do in the maintenance section .... somewhere  ::) and be carefull when you remove the seats re the air bag if fitted, & they're bloody heavy.  ;)  ;)  ;)
Ian_D
  • York
« Reply #2 on: 28 July 2009, 19:52:17 »
Does anyone even own an Omega, which the drivers heated seat still works?  ;D
[size=12]
« Reply #3 on: 28 July 2009, 19:56:04 »
ME!
It didn't though when I first bought it! You were still at school when I fixed it!  ;D  ;D  ;D  ;D
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 28 July 2009, 21:32:54 »
Actualy mine also works and the car is 10 years old :y
Not only that it works, the first time I turned it on it almost burnt my a..  ;D
« Reply #5 on: 28 July 2009, 21:40:12 »
Thanks ........ Rob
Have a gander here about changing heat pads http://www.omegaowners.com/forum/YaBB.pl?num=1192830810
« Reply #6 on: 28 July 2009, 21:46:46 »
Mine works .. and also the old miggy was fully functional .. :)
« Reply #7 on: 28 July 2009, 21:56:38 »
Mine does too, but it's a very common complaint on the forum!  ;) ;) ..... hence the maint guide.  ;) :y
kjf7
  • lincolnshire
« Reply #8 on: 28 July 2009, 23:49:29 »
me too front and rears  :y
I_want_an_Omega
« Reply #9 on: 29 July 2009, 07:45:26 »
Anyone got access to the part numbers to see whether I can rob the rears to put in the fronts?
elitekev
  • poole
« Reply #10 on: 29 July 2009, 08:22:39 »
all four of my heated seats work on an S reg
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« Reply #11 on: 29 July 2009, 12:38:05 »
Mine works, but that's on a 02 facelift.  When I bought it I did check to make sure that they worked in the front, despite it being a really sunny and hot day!
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
I_want_an_Omega
« Reply #12 on: 29 July 2009, 12:39:25 »
Part numbers anyone please?
« Reply #13 on: 29 July 2009, 18:24:34 »
All 4 work fine in my 11yr old MV6, though sports leather seats do seem to be more reliable, heater wise.
Don't have the part numbers, though I guess there are different as their electric characteristics are different
Agemo
  • Cleethorpes
  • Insignia
« Reply #14 on: 29 July 2009, 19:16:46 »
Only got front ones, but they work fine. I wouldn't mind retro-fitting them in the back if it's a fairly easy job.
« Last Edit: 29 July 2009, 19:17:15 by Agemo »
