Author Topic: Scuttle panel - wiring ok?  (Read 2281 times)
I_want_an_Omega
« on: 06 August 2009, 17:32:11 »
Hi,
Both my cars have the same "issue" insomuch as the wiring harness cables above the pollen filter have lost their "wrapping". Both cars are S reg an were built within a week of each other.
It looks like the tape has simply disintigrated over time. Apart from putting more tape on - does anyone have any comments?
Ziad
  • Bahrain
Re: Scuttle panel - wiring ok?
« Reply #1 on: 07 August 2009, 07:27:49 »
Hi,
Uh, IMHO, that should do it. you could use a few cable ties in there as well, to make sure the tape does not come loose later
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 07 August 2009, 22:14:36 »
I would like to think I would use something better than tape, just can't think what though. Plastic tubing???
I_want_an_Omega
« Reply #3 on: 10 August 2009, 22:20:04 »
I'll be using "self amalgamating" tape available from Maplin.
Will seal into a solid rubber mass once it sets.
