Author Topic: 03 2.2DTi CD - Replace CDR 2005 and add Amp  (Read 10788 times)
mardibloke
  • Nottingham
« on: 08 August 2009, 14:10:48 »
Read some great information here and just started pulling my recently acquired Omega apart. Before I start installing a new head unit and amp, couple of bits of guidance would am sure speed me along.
Routing 12+ve from battery to boot, think I see the two large bundles of cables behind the pollen filter, do I just try and push my new 12v feed cable down the side of one of those?
Mounting the amp - I see a big space behind the spare wheel, has anyone tried to mount an amp there, and if so how. If not I plan to try and bolt amp under the rear parcel shelf, which I assume is what most people do?
Loom/Wiring Speakers - I assume I need to run new cables from each speaker to my amp in the boot.  Unless there might be anything already in the loom I can use?  I see there looks to be a wire to power the amp in the loom, on the big Blue plugs for the head unit - I wonder where that ends up for example.
Rod,  UK
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: 03 2.2DTi CD - Replace CDR 2005 and add Amp
« Reply #1 on: 08 August 2009, 16:02:39 »
Yep  :y
Mounting the amp will really depend on the physical shape and size of the thing. I always make up an MDF panel and bolt it in place, although I have seen others gripseal a panel in place also. But make sure to paint or seal the mdf panel so it does not get affected by moisture / damp in the boot. Upside down is really a last resort, as with hot air from the components inside rising, the heatsink being underneath them is not ideal - it will still work, just not 1st choice.
Depends what power you are running to the speakers. The original wiring is good enough for around 100W per channel - so easiest place to pick up speakers is the ISO block at the rear of the head unit, just run 4 pairs of wires back from the amp. If higher power, then best to run new cables to the speakers directly.
Unsure what this blue plug is that you speak of?
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #2 on: 08 August 2009, 16:40:38 »
Routing 12+ve from battery to boot, think I see the two large bundles of cables behind the pollen filter, do I just try and push my new 12v feed cable down the side of one of those? .....
I've recently needed to run a 12v supply to boot and found a blanked off hole about 3/8" dia, just above the 2 large sections of loom.
mardibloke
  • Nottingham
« Reply #3 on: 08 August 2009, 16:42:37 »
Thanks Dave, all sounds sensible.
"Blue" plug is the on the loom that plugs into back of CDR2005.  But will just run speaker wire from a connection to that, to the amp outputs.
Rod,  UK
mardibloke
  • Nottingham
« Reply #4 on: 08 August 2009, 16:44:03 »
over on the passenger side behind the pollen filter too :/
Rod,  UK
« Reply #5 on: 08 August 2009, 16:47:03 »
Yes. Just above the cables you described ..... unless they filled it in on face lift cars. ::)  ;)  ;)
I didn't see it to start with though, it's dark in there!  ;D  ;D
mardibloke
  • Nottingham
« Reply #6 on: 08 August 2009, 17:39:00 »
Found it Andy - thanks
Will post a photo later.
Rod,  UK
« Reply #7 on: 08 August 2009, 17:51:13 »
 :y  :y  :y It's not obvious is it!  ;)  ;)
mardibloke
  • Nottingham
« Reply #8 on: 08 August 2009, 21:06:05 »
Small rubber bung was blending in with the darkness, muck and water in mine ( great guide to clearing out drain holes on this site  :) - which mind badly needed ).
Pulled the rubber bung with some pliers and neat little hole. Ok for my use as just running a small amp, may not be big enough for monster thick cable.  Made a 20 minute job take 5 minutes.
Need to add something around the wire to avoid it chaffing on the metal - will have a think about that tomorrow.
The white one is the top of the two that are behind the pollen filter, and just as you said this spare one is just a tad up from it.
« Last Edit: 08 August 2009, 21:07:19 by mardibloke »
Rod,  UK
mardibloke
  • Nottingham
« Reply #9 on: 09 August 2009, 22:49:21 »
Amp bolted in under rear shelf, getting rear parcel shelf out was a bigger job than expected, as the guides/posts on this site suggest, must have been an excess of glue holding it in.
Cheers for that tip, did as you suggested. Not sure if they best thing to do, but ran those speaker cables down passenger side with the power feed. Ran the phonos down the drivers side.
Just got it all connected up, and working as started to get dark. I'm not after an expensive/loud system (just using spare bits of kit I already had), but the speakers sound woeful  :-/ on my first quick test. Amp has variable controls for low and high pass - should I be messing with those - or are the speakers in the CD really that bad?
Oh, and I have a dining room full of Omega interior that may take a while to put back.  ::)
« Last Edit: 09 August 2009, 22:50:00 by mardibloke »
Rod,  UK
mardibloke
  • Nottingham
« Reply #10 on: 09 August 2009, 23:11:19 »
Didn't see it mentioned in other posts I read, but its a very tight squeeze to get another head unit it. Arranging the cables at the back of my single din cage is going to be tough.
Plus made life much easier to feed cables in, by removing the complete surround (incl. climate controls), and then the large plastic frame that makes the double din  support
Also the channel down passenger side of car is much neater for running cables and keeping them tidy. The cables running down drivers side don't have the plastic conduit for some of the way, so just tapped my phono cables to the existing cable run.
« Last Edit: 09 August 2009, 23:14:01 by mardibloke »
Rod,  UK
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 09 August 2009, 23:11:28 »
You are not connecting an amp to the standard Omega speakers are you?
Check the polarity of all the cables you have run to ensure that +ve and -ve do not change over anywhere or you will end up with a phase imbalance, and yes, that can sound awful.
mardibloke
  • Nottingham
« Reply #12 on: 09 August 2009, 23:18:44 »
Doh! It was getting dark, and I was sitting in the boot wiring the speaker cables to the amp.  /excuse #9872376
That would certainly explain the nasty sound.
I'm starting to think you already know what my next mistake will be and have the answer ready  :y
And yes, I was hoping to leave the speakers as standard.  Only having to run an amp as the head unit, I had spare in the garage and I want to use *only* has phono out.
Don't expect it to sound stunning, and wanted this to be cheap and look standard.
Rod,  UK
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #13 on: 09 August 2009, 23:22:38 »
Speakers are rated at around 20W from new, and only just cope with the standard head unit - do not use them on your amp at all, or it will get VERY expensive as things rapidly start going bang.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #14 on: 09 August 2009, 23:24:09 »
New speakers and tweeters all round then
 :-X
