Author Topic: Central locking ecu  (Read 2852 times)
dan-wilks
Central locking ecu
« on: 01 August 2009, 11:51:37 »
Can anyone tell me where the ecu is located please?
924boy
  • Rhuddlan, N. Wales
Re: Central locking ecu
« Reply #1 on: 01 August 2009, 12:16:54 »
in the drivers footwell, behind the plastic cover and bonnet release lever  :y
dan-wilks
« Reply #2 on: 01 August 2009, 12:19:03 »
dan-wilks
« Reply #3 on: 01 August 2009, 20:12:37 »
how does the plastic cover come off?  :-?
I_want_an_Omega
« Reply #4 on: 16 August 2009, 14:30:16 »
You will need to remove the cover (with the Vauxhall logo) of the long trim piece, then remove the torx headed screws underneath. The cover just prises off with a flat bladed screwdriver under one end - it just snaps in position.
This will allow the kick panel sufficient play to be removed once you have removed the single torx headed screw that holds it in place.
You will probably need to fiddle around with the bonnet release lever as wel to remove the trim - but thats easy enough.
Rgds
« Last Edit: 16 August 2009, 14:31:22 by I_want_an_Omega »
