Author Topic: VAG-COM  (Read 2091 times)
  • Auckland
    • Mazda MPV
VAG-COM
« on: 15 August 2009, 22:09:35 »
Has anyone got experience of using VAG-COM with the Omega?
My previous Omega was a 1994 with the ALDL interface that only talks to the tech1.
I now have a 2003 2.6 V6 Omega, I also have VAG-COM. VAG-COM claims to be able to talk EOBD. I will have a play tomorrow & report back. If anyone has had any previous success I would be pleased to hear of it.
I assume that if it does work it will just act as a code reader.
Re: VAG-COM
« Reply #1 on: 16 August 2009, 00:02:05 »
vagcom, as its name suggests, is for VAG cars.
Even if you do manage to get it to connect (unlikely I reckon), I suspect you will meaningless results back.
Pedal trick is the easy way to get codes from your 2.6
  • Auckland
    • Mazda MPV
Re: VAG-COM
« Reply #2 on: 16 August 2009, 18:12:09 »
I connected VCDS (the new name for VAG-COM) to my Omega today using the Ross Tech interface.
It did complain about some communication errors but it found the engine and gearbox ECU's and reported them to be free of codes.
I then ran 'live values' and got sensible live values when I pressed the throttle pedal (awkward when the fuse box lid is open).
Going to ask the supplier/developer about the communicationss errors before I try anything alse but it looks promising :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: VAG-COM
« Reply #3 on: 17 August 2009, 10:50:44 »
Although you may get some results by connecting VAG-COM, and a similar scenario if you use Tech2 on an Audi, due to some of the data that can inadvertantly be overwriiten by the use of the incorrect diagnostic equipment, I cannot stress how serious it can be if you make a mistake.
Keep VAG-Com for the VW and Audis
Tech2 for Vauxhalls   :y
Radio & Decoding Technician
www.dndservices.co.uk
