Author Topic: Converging low beams  (Read 3264 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 16 August 2009, 20:29:53 »
Are low HID beams supposed to converge ever so slightly or should they be dead straight ahead. Reason for asking is that there appears to be no way to adjust them vertically (side to side).
Re: Converging low beams
« Reply #1 on: 16 August 2009, 20:37:41 »
There are two marked/labelled adjusters on my headlights.  ;)
  • Doha, Qatar
« Reply #2 on: 16 August 2009, 20:45:28 »
Would that be the inner hexa adjuster on top of the light?
  • Doha, Qatar
« Reply #3 on: 16 August 2009, 20:52:34 »
No it isn't. There is a black protuding plastic lever which will allow side to side vertical adjustment.
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 17 August 2009, 09:48:40 »
You can adjust HID's manually both verticaly and horizontaly, BUT if you have Low beam warning adjustment is almost useless cause no matter what you do the result (vertical adjustment ) won't be good and lights will still be to low
  • Doha, Qatar
« Reply #5 on: 17 August 2009, 20:11:08 »
I know that the Hella headlamp allows vertical movement, but does anyone know for sure whether the DEPO one does as well? Couldn't immediately see any lever for DEPO lamp.
« Reply #6 on: 17 August 2009, 20:40:03 »
You're not looking for a lever, it's an adjuster you want to find ;)
  • Doha, Qatar
« Reply #7 on: 18 August 2009, 09:02:10 »
Sorry, I meant horizontal adjustment. Can you adjust the DEPO headlamps horiziontally - side to side? (Vertical is readily apparent).
