Author Topic: omega fans  (Read 3211 times)
Charlies Dad
omega fans
« on: 27 August 2009, 09:47:53 »
may sound daft but the two fans on the radiator, are they both suppose to work?
i only have one working ... fuse maybe ?
omegadan67
  • northampton
Re: omega fans
« Reply #1 on: 27 August 2009, 18:28:26 »
2 fans ?????
there should be 2 fans on the front of the rad for aircon and 1 behind the rad for cooling the car hth
A little infomation is dangerous in the wrong hands
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: omega fans
« Reply #2 on: 27 August 2009, 19:31:06 »
Yep, 2 on front of rad run with AC on. 1 behind rad runs when engine is hot.
That is how mine run anyway, never seen just one of the 2 infront run on its own.
Al
If it aint broken, you aint trying hard enough
Pete Elite
  • Uxbridge, Middlesex
Re: omega fans
« Reply #3 on: 27 August 2009, 22:27:22 »
Al
  Well Al if you want to see one that does your welcome to come and see mine ::) ;D.
Ian_D
  • York
Re: omega fans
« Reply #4 on: 28 August 2009, 21:34:14 »
Check your fuses in the compartment behind the battery...
[size=12]
