Author Topic: dot matrix screen  (Read 3442 times)
manton63
dot matrix screen
« on: 14 August 2009, 07:58:00 »
Hi all
Just bought a 1997 tourer and the dot matrix screen looks like an early computer game with lost pixels. Anybody know where I can get a replacement from? What sort of prices are they?Also is it much of a job to replace?
Thanks for any help.
Tony
  • Auckland
    • Mazda MPV
Re: dot matrix screen
« Reply #1 on: 14 August 2009, 08:12:03 »
On my Omega with fixed steering column I had to take the steering wheel off to take the instrument cluster out. I have seen claims that if you have a tilting column that the cluster will come out without taking the wheel off.
If you do take the wheel off then you have to take the airbag off first & then use a puller to get the wheel off the splines (don't hit the column to free it or you will shear the pin in the collapsible section of the column)
Bumbazor
  • Worksop
« Reply #2 on: 14 August 2009, 08:13:06 »
Have a look in the parts for sale section. You're likely to find someone breaking with the part you need.
You will have to identify which type of display you have, as there are different versions.
Not much of a job really. You'll have to remove some air vents and a few screws to get the dash out. Haynes also mentions you have to remove the steering wheel to remove the dash but I managed to do mine without removing the wheel.
Welung666
« Reply #3 on: 14 August 2009, 09:20:45 »
I agree with Bumbazor, no need to remove the steering wheel. Remove the top cowelling from the steering surround and then as you free the dash panel just tip the top out slightly first and it'll come out  :y
« Reply #4 on: 15 August 2009, 10:27:45 »
97 one with missing pixels, that will be type with computer lines below radio info line, and thus a 2 yellow/black connector setup.
Rolfy Dave
  • Kidderminster. West mids.
« Reply #5 on: 01 September 2009, 14:57:28 »
That'll be the one...
and I want/need one as well if anyone knows who may have one available  ????
Maybe I'll hear from someone off here soon.
PM me if you have one (with all the pixels intact of course ;) )
Thanks for looking.
Dave :y
« Last Edit: 01 September 2009, 14:58:08 by Rolfy_Dave »
I_want_an_Omega
« Reply #6 on: 01 September 2009, 14:59:12 »
PM me with any numbers off the back and I'll see if they match up with the couple that I've got in the garage.
Regards
« Reply #7 on: 01 September 2009, 15:12:08 »
Regards
Any full size MID with yellow and black connector should do. Getting one with right programming is probably too much to ask I reckon.
I_want_an_Omega
« Reply #8 on: 01 September 2009, 20:07:39 »
Why is there a variance, I can see that some would have xenon inputs but is there much else that can be different between models?
« Reply #9 on: 01 September 2009, 20:39:39 »
No yellow/black connector ones have HID headlights.  In fact, the only settings on these earlier ones from memory is engine size and gearbox type.  Settings on earlier types is purely around the fuel computer calcs, and being able to display gearbox errors
Rolfy Dave
« Reply #10 on: 02 September 2009, 12:23:24 »
Wholeheartedly agree  :y  I can take my dash out in under 4 minutes now...
Regards
Cheers mate.
PM sent...
Its GM 90 379 234 that I require.
Then, I wonder if it will need teching ???
Cheers,
Dave  :y
ps... Also been told that GM 90 509 217 will do as well
« Last Edit: 02 September 2009, 14:14:59 by Rolfy_Dave »
Page created in 0.062 seconds with 20 queries.
