Author Topic: elite seats into cd model - 2 questions pls  (Read 8487 times)
dpanic88
  • West Midlands
« on: 04 September 2009, 14:33:14 »
Hi, trying to put elite cloth seats into my cd estate.
Pass side works, just connected and all is good.
 Just pluged in drivers seat and nothing works.
The new seat has all the correct conectors, including the connectors to the car loom .
1. With the seat just plugged in should there be any response, without adding the extra power to the memory unit.
2. To add power to the memory unit, can I just tap into the loom on the drivers side or do you have run new power from the battery (to fuse box, etc)
I have a copy of the wiring in the memory unit - I just exspected some response from the seat without any extra changes am I incorrect?
I've put the old seat back in for now while I looks for the answers.
Thanks in advance
Rob
AndyVXR300
Re: elite seats into cd model - 2 questions pls
« Reply #1 on: 04 September 2009, 14:44:29 »
Hi Mate try this guide
http://images.omegaowners.com/images/faq/seats/elite_seat.pdf
and remember
Pins 1, 3 and 4 are live and pins 2 & 5 are negative. Using the existing wiring from the car, to the seats, connect live to pins 1,3,5 and your negative to pins 2 and 5. Hope that makes sense to you.
WWW.VXRONLINE.CO.UK
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 04 September 2009, 15:55:14 »
and remember
Erm - is that a new form of dual voltage on pin 5 then?
Radio & Decoding Technician
www.dndservices.co.uk
dpanic88
  • West Midlands
« Reply #3 on: 04 September 2009, 19:24:21 »
and remember
Hi, many thanks - the quide I've now printed and got the correct pin layout. I'll take the current feed to the power and earth and run some branches off it to the other pins (I'll solder them while the seat is off) - thanks just wanted to double check that was all. Many thanks .. May the oof be with you
Welung666
« Reply #4 on: 04 September 2009, 19:52:18 »
Where abouts in west mids are you dpanic?
dpanic88
  • West Midlands
« Reply #5 on: 04 September 2009, 20:52:35 »
Just sent a pm
dpanic88
  • West Midlands
« Reply #6 on: 06 September 2009, 18:35:33 »
and remember
Pins 1, 3 and 4 are live and pins 2 & 5 are negative. Using the existing wiring from the car, to the seats, connect live to pins 1,3,4 and your negative to pins 2 and 5. Hope that makes sense to you.
Final update - all now working, inc memory function. As per the guide, yes you need all the extra feeds and nice .. Many thanks.
AndyVXR300
« Reply #7 on: 06 September 2009, 19:29:23 »
and remember
Excellent, glad it all worked out for you !!
WWW.VXRONLINE.CO.UK
I_want_an_Omega
« Reply #8 on: 07 September 2009, 18:37:47 »
Did you have to use longer bolts as you do on he pre/mini facelift cars?
AndyVXR300
« Reply #9 on: 07 September 2009, 18:44:20 »
I used the longer bolts when i did mine yes
WWW.VXRONLINE.CO.UK
I_want_an_Omega
« Reply #10 on: 07 September 2009, 18:47:38 »
Ta, am just about to do mine and someone mentioned it was necessary so I got some.
dpanic88
  • West Midlands
« Reply #11 on: 10 September 2009, 20:36:40 »
Hi, yes checked with vx after looking up in the parts guide - m8 x 38 (I think) - vx said don't know, after showing them in the parts guide which ones - said had to be factory order - two weeks. I got some 8x40 from homebase instead - works fine and they don't catch in the runners. Regards.
  • Auckland
    • Mazda MPV
« Reply #12 on: 10 September 2009, 21:37:54 »
Are these bolts used to restrain the seat in the event of an accident?
If so then as the seat belt catch is attached to the seat they are considered to be part of the seat belt mountings.
The difference in strength between mild steel and the different grades of high tensile steel is astonishing. If the Homebase ones are mild steel then you may as well use liquorice :o
dpanic88
  • West Midlands
« Reply #13 on: 10 September 2009, 23:33:02 »
Hi, good call - will check and confirm. Regards
