Author Topic: obd code 19 speed signal no signal  (Read 2365 times)
wolfie
  • nr cambridge
« on: 14 September 2009, 10:50:54 »
would appriciate any advice on this , car cut out on sat then ran fine went out sun stopped then when i got back in it wouldnt start
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: obd code 19 speed signal no signal
« Reply #1 on: 14 September 2009, 10:53:06 »
If you have the code 19 it is your crankshaft sensor,
you will need to replace it, theres a how to in the maintenance guide :y
He who brakes Looses
To old to die young
« Reply #2 on: 14 September 2009, 13:03:41 »
Yep crank sensor nackered mate - replace :y
wolfie
  • nr cambridge
« Reply #3 on: 14 September 2009, 21:27:17 »
thanks a mil both of you thought it be that or cam sensor. will order one 2moro. pattern trade is £35 would a genuine be much more?
« Reply #4 on: 14 September 2009, 21:49:26 »
There are 2 types depending on the shape of the plug but geniune are so much more reliable :y
« Reply #5 on: 14 September 2009, 21:51:05 »
Just to add, if you haven't got one already a trade card which is included when you join Autobahn Stormers will save you a small fortune :y
