Author Topic: A/C fan staying on.  (Read 2435 times)
Pete Elite
  • Uxbridge, Middlesex
A/C fan staying on.
« on: 16 September 2009, 18:31:21 »
Hi,
    My o/s air-con fan stays on all the time when engine is off but ignition on, i pulled the 30amp fuse which shut it down so what could it be that's keeping it on, would it be a iffy relay?
         Thanks for any advise :).
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: A/C fan staying on.
« Reply #1 on: 16 September 2009, 23:26:23 »
Have you checked the relay?
it could be loose and just needs pushing home or cleaning.
http://www.omegaowners.com/forum/YaBB.pl?num=1176560725
one of the members here had the same problem, turn out to be a loose relay
He who brakes Looses
To old to die young
« Reply #2 on: 16 September 2009, 23:34:41 »
one of my engine fans stayed on for about 20 mins when we'd stopped on our way home from France. It turned off after I'd restarted the car & then turned it off again .....  :-/ :-/ :-/
Never had a problem before or since.  :-X
Pete Elite
« Reply #3 on: 16 September 2009, 23:58:15 »
Thanks Ghost ;) but I've checked all the relays and they are all clean and tight so if it is a relay problem then one or more must be u/s ::).
 Andy my o/s a/c fan comes on as soon as i start the engine and stays on :-?.
« Reply #4 on: 17 September 2009, 05:48:52 »
Not with the key in your pocket though!  ;)
Pete Elite
« Reply #5 on: 17 September 2009, 15:20:54 »
      No at least mine only goes with the key in the ignition and engine running ;).
