Author Topic: brake pad warning wires  (Read 8515 times)
bri cox
  • york
« on: 18 September 2009, 23:46:46 »
hi all me again just a little query regarding the beake pad warning wires should they be warning wires at the front on the left and right as mine only has it on the left my mates has them on the left and right his is a 2000 elite and my old v reg had the same as my mates did they change the design from 2001 onwards or has mine been cut some where  cheers bri
crazy
Re: brake pad warning wires
« Reply #1 on: 19 September 2009, 00:51:25 »
good news only one n/s front non on rear bad news they sell them in pairs
« Reply #2 on: 19 September 2009, 01:50:06 »
Only one on facelifts, 2 on pre & mini facelifts.
Can buy them singly from Vx (mine were part nš 90495144) or off ebay.
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
« Reply #3 on: 19 September 2009, 05:31:59 »
if you check the car regularly and are confident you will notice low pads they can be disabled, with a piece of wire, my gsi lived like it for 6 years as i change pads at 3mm. and like getting wheels off.
oh bugger, i thought that was a bit of wind!!!
bri cox
  • york
« Reply #4 on: 19 September 2009, 13:18:59 »
cheers everybody thats put my mind at rest thought i had to trace more wires and loose more hair with stress ;D
« Reply #5 on: 19 September 2009, 17:43:05 »
I have a facelift and there is one on the near-side and one on the offside set of pads. ;)
« Last Edit: 19 September 2009, 17:43:33 by Lizzie_Zoom »
RichardH
  • Ireland
« Reply #6 on: 19 September 2009, 17:49:30 »
I checked mine last week and only had them on the nearside.  They must have changed them around 2001.
« Reply #7 on: 19 September 2009, 17:56:07 »
I checked mine last week and only had them on the nearside.  They must have changed them around 2001.[/quote]
Correct :y
bri cox
  • york
« Reply #8 on: 20 September 2009, 00:59:57 »
thank you for that i was getting worried then so it is only on the near side from 2001 onwards :)
« Reply #9 on: 20 September 2009, 01:08:46 »
cos , provided both sides are maintained correctly ie pads not siezed in the calipers, if one side needs new pads .... then so will the other - & Vauxhall saved a couple of quid per car by reducing the sensors & plugs/sockets to the tune of ONE!!!!  :-?  :y   ;D  ;D
bri cox
  • york
« Reply #10 on: 20 September 2009, 01:36:47 »
i was just thinking about cobbiling another senser to the right hand side just in case something goes wrong even tho i like to maintain my on a regular basis
« Reply #11 on: 20 September 2009, 11:58:20 »
That sounds like you're trying to fix a problem you don't have.  ;)  ;)  ;)
bri cox
  • york
« Reply #12 on: 20 September 2009, 22:54:40 »
i got to agree you are right if it aint broke why fix it as my old man used to say :y
« Reply #13 on: 20 September 2009, 22:56:47 »
you know it makes sense!!!  :y  :y  :y
bri cox
  • york
« Reply #14 on: 20 September 2009, 23:04:44 »
i aint gonna make no changes unless its broke  :y
