Author Topic: CCR2005  (Read 4111 times)
CCR2005
« on: 01 September 2009, 15:08:03 »
I've got a CCR2005 in my facelift TD and want to make it sound better or maybe swap it over for a CCR 2006 if thats any better. I intend to fit a blind/rear parcel shelf so was considering some 6x9s but know nothing about ICE so any advice would be greatfully received.
TIA :y
Re: CCR2005
« Reply #1 on: 01 September 2009, 15:14:14 »
ccr2006 does sound better than ccr2005.
Beyond that, you're looking Bose setup (with either CCR, CCRT or NCDC headunits) or aftermarket.  I know what road I'd go down, much to Dave DND's annoyance, but then I like the factory fit look, and I'm tight!
Re: CCR2005
« Reply #2 on: 01 September 2009, 15:23:03 »
I agree. Is the wiring there like on the mini facelifts?
Re: CCR2005
« Reply #3 on: 01 September 2009, 15:27:05 »
ccr2006 (non bose) is straight swap. Bose needs a bit of work getting wiring to kick panel ready for bose loom. Both CCRT and NCDC need some wiring mods and new displays.
Re: CCR2005
« Reply #4 on: 01 September 2009, 15:39:13 »
Hmmm, might just opt for the CCR2006 then ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2005
« Reply #5 on: 01 September 2009, 16:04:19 »
Can`t disagree with that upgrade   :y
And you would only annoy me if you chose to go down the awfull BOSE route.
 :P
Radio & Decoding Technician
www.dndservices.co.uk
Re: CCR2005
« Reply #6 on: 01 September 2009, 16:10:38 »
Is it worth fitting better speakers?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2005
« Reply #7 on: 01 September 2009, 16:17:54 »
Absolutely !!
Re: CCR2005
« Reply #8 on: 01 September 2009, 16:20:09 »
Absolutely !!
So what would you recommend Dave, within reason ::) say £100 to £150ish
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2005
« Reply #9 on: 01 September 2009, 16:23:13 »
Good realistic budget for speakers.
Will you be considering a small amp to run them from the OEM head unit, (look at Focal) or just looking to power them from the head unit directly? (look at clarion)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2005
« Reply #10 on: 01 September 2009, 16:24:24 »
What size speakers do you need?
Re: CCR2005
« Reply #11 on: 01 September 2009, 16:25:25 »
Probably just from the head unit, unless its quite easy to wire an amp in.
« Last Edit: 01 September 2009, 16:25:40 by Elite_Pete »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2005
« Reply #12 on: 01 September 2009, 16:30:47 »
Clarion SRQ range then -
let me know what physical size seakers you need and I`ll point you at them on our website
Do you need spacers also?
oceansoul
  • Sunbury on Thames - Surrey
Re: CCR2005
« Reply #13 on: 02 September 2009, 17:53:28 »
i belive there 17cm, 6.5"
not sure why i belive that tho....just seams to be stuck in my head :S
« Last Edit: 02 September 2009, 17:54:18 by oceansoul »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR2005
« Reply #14 on: 02 September 2009, 17:59:42 »
Our most popular entry level 17" component set that does not compromise on sound quality - ideal for running on a standard non-amplified head unit.
http://www.dndservices.co.uk/srq1720s.html
