Author Topic: Radio Fuse  (Read 2122 times)
Radio Fuse
« on: 13 September 2009, 22:39:41 »
Is the Radio fused as a separate unit anywhere? mine has stopped working but everything else is fine ::)
Welung666
Re: Radio Fuse
« Reply #1 on: 13 September 2009, 22:44:53 »
Some head units have a fuse in the back of the unit next to the ISO plugs :y
Re: Radio Fuse
« Reply #2 on: 13 September 2009, 23:07:04 »
I thought / hoped that, best get it pulled out then, but can't find my wire, radio remover, things ::) 4 little screwdrivers then..... :D
trademeister
  • Rotherham
Re: Radio Fuse
« Reply #3 on: 26 September 2009, 22:01:41 »
The radio is on the same fuse as the dash so if the dash is still working it must be a problem with the radio itself mate. Hope this helps.
Re: Radio Fuse
« Reply #4 on: 27 September 2009, 01:13:19 »
mine has fuse next to iso plug. As did the one on my pre face lift iirc.
Can get away with small bobbly allen keys if you cant fine your radio keys.
