Author Topic: No EML lit.  (Read 1728 times)
BILLBADGER
  • ST ALBANS
No EML lit.
« on: 03 October 2009, 13:24:40 »
I have 2.6 Y reg, EML does not light up when key is turned in the ignition and the engine won,t start.
Can anyone help. Thanks.
Re: No EML lit.
« Reply #1 on: 03 October 2009, 13:56:26 »
Put the bulb back in, then do a pedal trick
BILLBADGER
  • ST ALBANS
Re: No EML lit.
« Reply #2 on: 03 October 2009, 16:36:00 »
When you say put the bulb back in I assume you mean replace the bulb. Thanks
Re: No EML lit.
« Reply #3 on: 03 October 2009, 16:44:30 »
Take the instrument panel out http://www.omegaowners.com/forum/YaBB.pl?num=1192573381
If you haven`t got a spare bulb use one of the existing then re-fit panel and do the pedal trick :y
BILLBADGER
  • ST ALBANS
Re: No EML lit.
« Reply #4 on: 03 October 2009, 19:22:35 »
Thanks for the info, will do it in the morning.
