Author Topic: xenon adjustment  (Read 2143 times)
diversteve
xenon adjustment
« on: 10 October 2009, 08:34:24 »
Does anyone know how to adjust the xenon headlamp for use abroad. There is a little lever to the side that appears to move sideways and is marked L-arrow R arrow but is not moving
Car is an omega cdx leather 2002 v6 2.6
Any help welcome.
Diversteve
diversteve
Re: xenon adjustment
« Reply #2 on: 10 October 2009, 15:39:05 »
With reference to the picture in the manual, my headlamps appear to be different,perhaps they are not xenon, they have a sticker warning of high voltage. The little lever is horizontal and will not move easily. Any other ideas?
« Last Edit: 10 October 2009, 15:40:21 by diversteve »
« Reply #3 on: 10 October 2009, 15:54:04 »
The levers move up or down. The manual gives the position, but the correct position ends up with one up & t'other down. If the sticker warns of high voltage & they take a second or so to 'warm up', then you have HID's  :y  :y
diversteve
« Reply #4 on: 11 October 2009, 21:18:54 »
So ,is it possible to adjust the HID headlamp and if so is it the same as the manual shows only mine will not move.
« Reply #5 on: 12 October 2009, 00:46:27 »
Something's seized then, they should move relatively easily.  ;)
« Reply #6 on: 12 October 2009, 19:46:21 »
They move VERTICALLY ... do NOT apply any inwards or outwards pressure or you'll snap the internals !!
As said .. should move with light finger pressure only ... and the hardest part is getting your hand in by the battery.
As we go to France on a reguklar basis and I adjust the lights at the port I've moved the battery as far back as I can get it to give a tad more access.
With practice it only takes a minute or so .. :)
« Reply #7 on: 12 October 2009, 21:04:53 »
Mine are still set for a level beam cos I struggle getting my hand in
 ....... last used in France in July!  ::) :y
