Author Topic: key fob  (Read 5251 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
key fob
« on: 12 October 2009, 19:09:54 »
hi guys and girls, just a quickie. should the led come on when you press the fob.i have 2 fobs nether light up and the cl don't work,the answer is probably on hear some where.but any help apreciated :y
Re: key fob
« Reply #1 on: 12 October 2009, 19:10:40 »
yes. Check batt holder isn't busted
moggy
  • hartlepool
Re: key fob
« Reply #2 on: 12 October 2009, 19:12:36 »
Hi tb holder looks ok
Welung666
Re: key fob
« Reply #3 on: 12 October 2009, 19:18:01 »
try a new battery then :P
moggy
  • hartlepool
Re: key fob
« Reply #4 on: 12 October 2009, 19:21:57 »
welung 666 2new battries put in back to back if you know what i mean still no joy :(
Martin_1962
Re: key fob
« Reply #5 on: 12 October 2009, 19:22:38 »
Duff switches?
Broken leg on batttery holder?
2 or 3 button?
Martin_1962
Re: key fob
« Reply #6 on: 12 October 2009, 19:23:08 »
Two together could damage the board
Welung666
Re: key fob
« Reply #7 on: 12 October 2009, 19:28:07 »
I think he meant one after the other not at the same time ;D
moggy
  • hartlepool
Re: key fob
« Reply #8 on: 12 October 2009, 19:28:18 »
hi martin its 2 button its not the original fob but has been working for the last 2 years.its got a button on the top and a button on the side and takes 2 battrys code cr2025 :y
Welung666
Re: key fob
« Reply #9 on: 12 October 2009, 19:29:19 »
Ohhh it's an IR remote and it is original
moggy
  • hartlepool
Re: key fob
« Reply #10 on: 12 October 2009, 19:51:02 »
welung666 whats ir remote and is that good or bad :-?
Welung666
Re: key fob
« Reply #11 on: 12 October 2009, 20:34:51 »
IR = Infra Red, do you have a red dome up near the interior light/rear view mirror?
moggy
  • hartlepool
Re: key fob
« Reply #12 on: 12 October 2009, 20:39:00 »
Yes mate i do its next to the manual ajustment for the sun roof
Welung666
Re: key fob
« Reply #13 on: 12 October 2009, 20:47:47 »
It's the older system then, you virtually need to be in the car for it to work with a good battery! And yes there should be a red LED on the fob when you press a button. Where abouts are you? If you're near I'll gladly have a look for you.
moggy
  • hartlepool
Re: key fob
« Reply #14 on: 12 October 2009, 20:59:48 »
Welung that would be most excellent,i am near birmingham airport in chelmsley wood. :y
