Author Topic: main beam headlights  (Read 2283 times)
tat2dee
  • manchester
« on: 13 October 2009, 19:15:30 »
hi all, i'm hoping someone can give me a clue where to start looking for the cause of my main beam headlamps turning themselves on and only going out when i removed the fuses, the light switch , ignition etc made no difference, car is a 2000 elite, dip beams are xenon and work normally, as do the side lights. >:(
Re: main beam headlights
« Reply #1 on: 13 October 2009, 19:33:25 »
indicator/flash stalk u/s??  :-/
steve-o2.5
  • Fort William
« Reply #2 on: 13 October 2009, 21:55:36 »
hi had this problem on my vectra, the stalk was shorting out, could hear it buzzing and main beam would flash then stay on. had to get a new stalk
tat2dee
  • manchester
« Reply #3 on: 14 October 2009, 19:19:04 »
thanks , i'll check it out  :y
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
« Reply #4 on: 15 October 2009, 12:50:54 »
Hi just sorted this on my 2.5TD. New switch  two wire jobby as recomended by those that know on this site (Thank a lot)£48 odd quid fitted in no time. Problem solved, no hiccups with the cruise control either. Plug and play!
deviator
  • Chesterfield
« Reply #5 on: 15 October 2009, 15:22:00 »
I might have a stalk if you are interested.
