Author Topic: Air Con Doesn't Work  (Read 3523 times)
Humpy
  • Tunbridge Wells, Kent
« on: 20 October 2009, 16:38:15 »
Just bought another Omega for the missus and the air con doesn't work. I looked at it before but realised the air con didn't work (amongst some other niggles) and walked away. When the price came down to what I wanted to pay I bought it! Now a mate, when I mentioned about the air con said that the compressor won't cut in if there's no gas in the system. Is that right? The light comes on the switch but I can't hear a relay. Is there a relay? I checked the fuse and that seems ok, I see on another thread that there's some big fuses for the air con by the battery? Any advice would be welcome, thanks.
Humpy
« Last Edit: 20 October 2009, 16:38:47 by Humpy »
Re: Air Con Doesn't Work
« Reply #1 on: 20 October 2009, 16:40:03 »
.... Now a mate, when I mentioned about the air con said that the compressor won't cut in if there's no gas in the system. Is that right?  .....
Correct!  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 20 October 2009, 17:29:36 »
Can`t speak for your neck of the woods, but around here, Kwick-Fit are about the cheapest for re-gassing
Last one I had done was a VW Sharan - cost me £30
Radio & Decoding Technician
www.dndservices.co.uk
Humpy
« Reply #3 on: 20 October 2009, 21:44:13 »
Thanks guys, I'll give it a go then :y
Humpy
« Reply #4 on: 20 October 2009, 21:47:55 »
Didn't they break it up Dave?  Kwikfit are well known for that - they managed one of ours as well as a lot of other members' cars!!  Best to get an A/C expert - we use a mobile guy just as economic as Kwikfit but knows what he's doing!!
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #5 on: 20 October 2009, 21:49:02 »
Most likely to be lack of gas, but low coolant level will also stop the compressor kicking in :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
Humpy
« Reply #6 on: 20 October 2009, 22:48:47 »
As in low engine coolant? Why's that then?
Humpy
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #7 on: 21 October 2009, 08:04:29 »
I noticed this originally a few years ago with a Fiat - the heater matrix was leaking, and when the coolant dropped below a certain level, the compressor would no longer kick in until topped up. I had my Omega serviced a few weeks ago, and during the service the coolant was changed - when the car was running with the coolant low (and the coolant check warning on the MID), the compressor would not run - as soon as we topped it up to minimum, it started. :y
« Reply #8 on: 21 October 2009, 08:30:51 »
There is some coincidence there then as there is no connection betweeen the coolant level sensor and the aircon operation.
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #9 on: 21 October 2009, 09:09:35 »
Perhaps so - there was no conicidence on the Fiat as I traced it out on the wiring diagram and the climate ECU did check the coolant level sensor as one of its inputs.
Don't know for certain on the Omega - but JamesHoleinblockV6 was there when it happened!!! :y
  • Auckland
    • Mazda MPV
« Reply #10 on: 21 October 2009, 11:12:20 »
My pre-facelift (A/C not climate) used to start the ventilation and compressor as soon as you started the engine. My 2003 facelift with climate control seems to delay starting the ventilation for some time after starting the engine. Don't know what it is waiting for :-/
I don't know whether this is evidence for 'coincidence' or some link between the climate system and the MID/ECU/warning lights that isn't apparent on the wiring diagrams :-/
« Reply #11 on: 21 October 2009, 11:30:07 »
Its because its a more advanced setup, there is little point in winding up the ventilation if you want heat and the engines just been started.
An Omega has no connection between coolant level and aircon.
espen22
  • Norway(the coldest part of it)
« Reply #12 on: 22 October 2009, 07:24:49 »
I would have checked the connections underneath the car, there is two plugs going into the aircon pipes that measures pressure and temperature on the system. theese connectors are wery exposed to destruction if the car is driven without the bottom engine plate!
And on the older models the wirings are bad, they intend to break near the connectors causing bad connection.
If this connectors are ok, i would also given one of the fillvents a little push to see if there is some gas in the system, if totally empty you might have a leak somewhere, and that leak can be in one of the quick connectors located around the system.
