Author Topic: Parking sensors  (Read 2021 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Parking sensors
« on: 24 October 2009, 18:02:44 »
The wife's new elite estate has parking sensors and i don't think they are working the way they should. when you put it in reverse you get a single short note and then it just gives a continual note and does not change at any distance. It only stops when you take it out of reverse. has anyone had this before. :-/
    • 530D M Sport, 330i Coupe
Re: Parking sensors
« Reply #1 on: 24 October 2009, 20:09:36 »
Yep, happens occasionally on mine.
Could try unplugging the park pilot unit in the boot area then plugging it back in, also worth cleaning the park sensors.
amba
  • Medway towns
    • German V6
Re: Parking sensors
« Reply #2 on: 24 October 2009, 20:33:42 »
I have after market Cobra ones fitted to my Mega and sometimes they do the same thing.I think it is caused by accumulation of dirt or water and one thinks it is close to an object.Agree with VXL V6...disconnect and give good clean then refit..also worth giving them a good wipe every so often,especially now weather is turning .
Re: Parking sensors
« Reply #3 on: 25 October 2009, 00:30:15 »
only time i've had agro was when some donkey fitted the lpg  ::) and didnt push one of the sensor connecters fully home...
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: Parking sensors
« Reply #4 on: 25 October 2009, 07:44:25 »
would not have thought it would be down to dirt or muck tbh but maybe wrong not sure bout the miggy`s sensors but when i worked for volvo if they had them fitted they were colour coded to match the bumper and they still worked fine
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Parking sensors
« Reply #5 on: 25 October 2009, 07:46:36 »
Thanks to all of you i will try and have a look today and let you know what i find. it's the first time we have had the sensors so its all new to me. :y
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Parking sensors
« Reply #6 on: 25 October 2009, 16:26:35 »
had a look this after and still can't see the fault any other ideas and as this is an estate were is the unit in the boot area? so i can try the unplug thing.
