Pages: 1 2 3 4 5 6 7 [8] 9 10   Go Down
Author Topic: Dash Lights  (Read 25356 times)
I_want_an_Omega
Re: Dash Lights
« Reply #105 on: 02 September 2009, 17:57:00 »
But I presume that they all show a short circuit to ground as that is what you are seeing from terminal 58d which is the output from the switch?
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
Re: Dash Lights
« Reply #106 on: 02 September 2009, 18:05:14 »
tbh, I don't know, I was just taking instructions from TB's post on Page 6 of this thread. I'm a bit uncertain when it comes to  electrics and this has me well puzzled
John
I_want_an_Omega
Re: Dash Lights
« Reply #107 on: 02 September 2009, 18:36:30 »
Ok, not to worry. I nearly finished the list but my PC then  crashed and I lost the lot. I have to go out now but will look later.
One thing that I did notice was that it also seems to go to the connector for a mobile phone install. Did your car ever have a mobile phone kit installed by a previous owner? Any telltale signs possibly? Have you removed a phone kit?
The connector is up behind the glove box.
More later I'm sure!  :(
Regards
Ratty
  • Coventry
Re: Dash Lights
« Reply #108 on: 02 September 2009, 18:40:24 »
Not as far as I'm aware, but it did have a CCRT700 installed which has a phone integrated into it, but that has now been taken out and the dash lights did work after it was removed
John
I_want_an_Omega
Re: Dash Lights
« Reply #109 on: 02 September 2009, 18:46:19 »
I think the phone wiring is still there as its a part of the loom.
Its unlikely that it could have been damaged, but just trying to cover all the bases as they say!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Dash Lights
« Reply #110 on: 02 September 2009, 19:12:19 »
I`m also happy to cast a glance over a circuit diagram if you have one you could email to me?
Radio & Decoding Technician
www.dndservices.co.uk
Re: Dash Lights
« Reply #111 on: 02 September 2009, 19:47:01 »
Is it possible to get to the back of the socket where switch plugs in, I'm beginning to suspect something behind there, esp as it happened after changing switch.
Pin 9 is the same as 58D BTW
Ratty
  • Coventry
Re: Dash Lights
« Reply #112 on: 02 September 2009, 19:54:09 »
Yes, there's loads of room I've checked, double chacked and checked again and as far as I can see all the connectors are sound and in their correct positions. the loom side of the switch can be pulled out from it's dash holder leaving it free if you get my meaning, I can take a Pic of it if it will help.
John
Ratty
  • Coventry
Re: Dash Lights
« Reply #113 on: 02 September 2009, 20:10:02 »
Dunno if it will help but...
John
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Dash Lights
« Reply #114 on: 02 September 2009, 20:40:33 »
Is there a voltage on 58d with the switch fitted?
Ratty
  • Coventry
Re: Dash Lights
« Reply #115 on: 02 September 2009, 20:58:14 »
sorry to sound a bit dense, but how would I connect the multimeter to check that?
John
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Dash Lights
« Reply #116 on: 02 September 2009, 21:04:21 »
Meter set to the V 20 setting on the left.
Black meter wire to earth / ground / anything metal
Red meter wire to 58d (pin 9)
What does the meter say with lights on / off / dimmer / any position of the switch
« Last Edit: 02 September 2009, 21:07:18 by Dave_DND »
Ratty
  • Coventry
Re: Dash Lights
« Reply #117 on: 02 September 2009, 21:06:34 »
Ok ta, will check it in the morning when i have some light out there :)
John
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Dash Lights
« Reply #118 on: 02 September 2009, 21:10:05 »
As no one seems to be able to send me a diagram - can somebody determine what supply and output voltages should be seen at the connector at the rear of the switch?
Lets at least try to determine if we have a supply to be working with ?
Ratty
  • Coventry
Re: Dash Lights
« Reply #119 on: 02 September 2009, 21:14:52 »
TB says the Haynes manual has the circuit on track 1532, I have that diagram that I can scan if it's any help, it's effectively useless to me as It might as well me in Chinese to me :(
John
Pages: 1 2 3 4 5 6 7 [8] 9 10   Go Up
