Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Down
Author Topic: Dash Lights  (Read 25411 times)
Re: Dash Lights
« Reply #75 on: 01 September 2009, 17:43:49 »
tried that earlier, was told that pin 58d was the dimmer control circuit put a 12v feed to that and the bridge wire started to get warm so disconnected it before any damage was done
I was thinking more along the lines of connecting directly to a bulb, so that you could eliminate any control circuitry in the test and to make sure that the circuit itself was free from shorts and illuminated.
At least that way you could track backwards to see at which point you are losing the supply voltage
If my theory is right, that may do more damage than it cures :(
Re: Dash Lights
« Reply #76 on: 01 September 2009, 17:44:43 »
One last little test. Do the rear fog lights work (engine running, lights on, rear fogs on)
yes, they work as do the fronts :y
Right, excellent.
Do you have a reasonable multimeter?
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
Re: Dash Lights
« Reply #77 on: 01 September 2009, 17:47:24 »
it's a cheapo digital one like this...
John
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Dash Lights
« Reply #78 on: 01 September 2009, 17:50:05 »
No mate, thats not a cheapo meter - what you have there is absolutely perfect
As long as you know how to use it
Radio & Decoding Technician
www.dndservices.co.uk
Re: Dash Lights
« Reply #79 on: 01 September 2009, 17:54:08 »
that is ideal :y
Right, go pull out headlight switch, I'll post up diagram of where to stick it, ooo-err missus
Ratty
  • Coventry
Re: Dash Lights
« Reply #80 on: 01 September 2009, 17:56:07 »
oki koki :D
John
Re: Dash Lights
« Reply #81 on: 01 September 2009, 18:03:47 »
This is the loom side of plug (I think, the switch itself has the male connectors on?)
With meter on 200ohms setting, what do you get between pins 9 and 12 on loom side connector?
Re: Dash Lights
« Reply #82 on: 01 September 2009, 18:05:00 »
expecting a short....
Ratty
  • Coventry
Re: Dash Lights
« Reply #83 on: 01 September 2009, 18:10:11 »
ign on or off?
John
Re: Dash Lights
« Reply #84 on: 01 September 2009, 18:12:40 »
ign on or off?
off
Ratty
  • Coventry
Re: Dash Lights
« Reply #85 on: 01 September 2009, 18:18:14 »
it shows 00.6 which i would assume means short
John
Re: Dash Lights
« Reply #86 on: 01 September 2009, 18:44:18 »
sadly, what i expected.
Right, remove ashtray, remove radio (inc any adapters in use to get it to fit Omega loom), disconnect snow switch and gearbox selction panel.
Then remeasure
Re: Dash Lights
« Reply #87 on: 01 September 2009, 18:44:41 »
i think you can see where we are going with this :(
Re: Dash Lights
« Reply #88 on: 01 September 2009, 18:46:07 »
I'd go out and measure mine for comparison, but don't feel too good, so sat here with glass of water, and ain't moving for anyone  :-[
Ratty
  • Coventry
Re: Dash Lights
« Reply #89 on: 01 September 2009, 18:47:57 »
Not quite sure, the instrument panel?
John
Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Up
