Author Topic: power problem  (Read 1688 times)
iceman
  • Maidstone, kent
power problem
« on: 29 October 2009, 21:21:43 »
You know when you take your key out of your ignition you still have a small amount of power running that powers your central locking and saves all your radio channels well mine seems to cut off completely anyone know how i can rectify this problem :'(
KillerWatt
Re: power problem
« Reply #1 on: 29 October 2009, 21:51:21 »
Check the fuses is probably a good starting point.
If you don't understand the symbols on the fusebox lid/cover, give us a clue as to what you have (model/engine/year) and someone will be along shortly to tell you just what fuse to look at.
Re: power problem
« Reply #2 on: 29 October 2009, 22:15:45 »
may be better posted in the electrical section?
Re: power problem
« Reply #3 on: 30 October 2009, 10:46:19 »
[movedhere] Omega General Help [move by] Kevin Wood.
Re: power problem
« Reply #4 on: 30 October 2009, 10:48:02 »
Done.
As said, check the fuses are all OK. If my wiring diagrams were loading( ::)) I would have a look and see if the radio memory supply and central locking share a common fuse.
