Author Topic: Horn sound  (Read 3533 times)
cruisetopoland
  • UK
Horn sound
« on: 24 October 2009, 21:54:29 »
What should the horn on my 2000 2.2 CD sound like-it sounds like its off a Micra!! Pip pip...
Should it not be a twin tone loud paaaaarrppp one? It sounds daft on a car this size.
Comments please...!
Re: Horn sound
« Reply #1 on: 24 October 2009, 22:13:15 »
Comments please...!
I'd have thought all Omegas should have twin tone horns, even my crappy Astra has. My cars have a 400Hz & 500Hz horn, I'd expect yours should too. :y  :y  :y
A new horn from Vauxhall is around £20 ....obvioulsy somewhat less from a scrappy.  :y
« Last Edit: 24 October 2009, 22:14:29 by Andy_B »
cruisetopoland
  • UK
Re: Horn sound
« Reply #2 on: 24 October 2009, 22:20:36 »
Where is it located-seems to be by OSF headlight, but can't see it...?
Re: Horn sound
« Reply #3 on: 24 October 2009, 22:26:32 »
beind the nearside of the front bumper IIRC. One of mine failed on the Omega and it was cos the plastic convoluted conduit had rubbed through the wiring & cut the end of the loom off. Half hour with as oldering iron & a roll of tape sorted it.  :y
Try swapping over each horn on the individual plugs & see what happens. It could either a duff horn (like my Astra) or duff wiring (like my Omega)  :y  :y
cruisetopoland
  • UK
Re: Horn sound
« Reply #4 on: 24 October 2009, 23:08:08 »
I'll have a look-cheers!!
cruisetopoland
  • UK
Re: Horn sound
« Reply #5 on: 25 October 2009, 16:29:28 »
Found the answer-someone has removed the front horn/left the wire for it hanging down, so only the rear one is working, hence the feeble pip!!
Is the front one different to the rear one-different sound?  How to source??
Thanks for the help...
Welung666
Re: Horn sound
« Reply #6 on: 25 October 2009, 16:36:54 »
Got a pair here ;)
Re: Horn sound
« Reply #7 on: 25 October 2009, 17:12:18 »
As said above ..... one is 400Hz & the other is 500Hz
cruisetopoland
  • UK
Re: Horn sound
« Reply #8 on: 29 October 2009, 13:30:22 »
Well many thanks to welung666; the parts have arrived  :y
I did a quick plug in test on the front (400hz) one and nothing-must be the wiring as suggested.
Will swap them about and have a play when I can get it up on a ramp, but would think the fromt one was removed previously as it did not work, so probably a wiring fault.
Any particular part of the wiring to look for faults??
Welung666
Re: Horn sound
« Reply #9 on: 29 October 2009, 18:28:13 »
Check the wiring behind the horns, they tend to chaff on a sharp edge higher up, bit of solder and it'll work :y
cruisetopoland
  • UK
Re: Horn sound
« Reply #10 on: 29 October 2009, 20:51:33 »
Will do, cheers-all I need is a ramp  :y
Too fat to get underneath otherwise  ;D
cruisetopoland
  • UK
Re: Horn sound
« Reply #11 on: 05 November 2009, 11:12:34 »
Well, thanks to help and advice on here, managed to source another horn, fit it and is all working fine now.
I ended up fitting 2x 500hz horns, facing opposite ways-sounds different to standard 400hz + 500hz twin tone, sounds like a 70s Peugeot.   Love it  :y
Cheers all, especially welung666 for the package  :y :y :y
