Author Topic: Ice hints and tips  (Read 2881 times)
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
Ice hints and tips
« on: 08 November 2009, 19:43:52 »
I like my beats and I have a sub, amp and 12 disc changer to fit, I need tips on how and where to feed the wires from the headunit through the dash
can anyone help?
2000 Omega Elite 2.5 V6
Welung666
Re: Ice hints and tips
« Reply #1 on: 08 November 2009, 20:21:52 »
Amp power wire through the large grommit under the pollen filter. All the other cables from the head unit out of the passenger side above the toe cover and they all run down the passenger side cable runs to the boot :y
« Reply #2 on: 08 November 2009, 20:21:59 »
can anyone help?
There's a bung in a hole about 1/2" dia just above the two sections of loom where the pollen filter is. You'll need a torch .... it is there - honest!  :y  :y
omegadan67
  • northampton
« Reply #3 on: 08 November 2009, 20:54:45 »
can anyone help?
you can run the amp power cable down the passenger side in under the pollen filter down to the sill trim panels and in to the boot.
while you are at it run the amp remote lead that way as well.
i ran the phono leads down the centre of the car under the centre console using flat leads
A little infomation is dangerous in the wrong hands
Blackie_No1
    • Omega Elite 2.5
« Reply #4 on: 09 November 2009, 10:58:30 »
How do I get the phono and cd changer leads from the back of the radio though? I can't see any holes in the radio aperture to feed them through?
Tim7
  • Wiltshire
« Reply #5 on: 09 November 2009, 15:08:36 »
Hi Blackie, ran my amp feed through the bulk head as the others have said and down the passenger side to boot, I took out the glove box to ease access to the back of dash and you need to remove to radio, still not a lot of room very tight behind the radio, took about 30 mins to get the radio back in, too many wires not enough apace. >:( But worth it  :y
Blackie_No1
    • Omega Elite 2.5
« Reply #6 on: 09 November 2009, 19:20:45 »
Coolio, sounds like a niht of fun ahead of me lol
