Author Topic: ABS & TC light coming on  (Read 5386 times)
The Duck.
  • Enniskillen. Co Fermanagh.
« on: 08 November 2009, 15:19:06 »
Hi hope some1 here can help me with my problem. The car is a 99 2.5 V6 Elite Auto and sometimes when driving ( more than ever now) the ABS & TC light come on together. The speedo stops working and the cruise control. If u drive it a distance it will go off again r if u stop take out the key and leave a few seconds it fine for another while. Its more annoying than anything else plus i got a speeding ticket the other day >:( Anyway any suggestions would help. Thanks guys :)
Re: ABS & TC light coming on
« Reply #1 on: 08 November 2009, 15:25:21 »
sounds like your ABS ECU is failing
The Duck.
« Reply #2 on: 08 November 2009, 15:26:40 »
Any idea off a prtce 2 replace >:(
« Reply #3 on: 08 November 2009, 15:29:08 »
Not on price but its not a fun job to replace  :'(
The Duck.
« Reply #4 on: 08 November 2009, 15:30:36 »
Never is on these  ;D would i b better going 4 a new 1 r second hand
« Reply #5 on: 08 November 2009, 15:31:45 »
you can get them re-furbished, i shudder to think what Vx would charge new, prob best to contact one of the breakers here.
« Last Edit: 08 November 2009, 15:31:58 by tunnie »
The Duck.
« Reply #6 on: 08 November 2009, 15:33:11 »
Cheers thanks :D
« Reply #7 on: 08 November 2009, 15:43:22 »
Deffo abs ecu knackered mate!
Second hand one expect to pay around £45 - £55 for one - try and get one from exactly same year and model (incl g/box type) as yours - wont then need Tech2 session.  (Part Nş on bottom of ecu :()
Refurb on yours - expect to pay upwards of £130.
I went used route on the Estate.
B*gger of a job to do - bottom four bolts you cannot see - undo by feel - very little space to work.  But a doable job - just needs a lot of patience and the right tools!!
Good luck  :y
amba
  • Medway towns
    • German V6
« Reply #8 on: 08 November 2009, 19:38:07 »
Mine was removed by local garage..as I live very close to BBA took it to them on a Thursday and fully refurbished by Monday ..£110=00 and 1 year warranty ,then local garage refitted it.
they said it was easier to remove from below and they took of the entire pump and abs assembly as quicker ??
« Reply #9 on: 08 November 2009, 22:12:28 »
But may need tech2 to bleed abs block!!
The Duck.
« Reply #10 on: 09 November 2009, 01:28:36 »
so another words i need 2 take it off 2 get the correct part number what a bummer  >:(
« Reply #11 on: 09 November 2009, 01:42:00 »
Fraid so mate  :(  Or take a chance and get one from exact same model/spec/year
The Duck.
« Reply #12 on: 10 November 2009, 01:49:43 »
Rite would any1 have 1 for the year and model above???????
« Reply #13 on: 10 November 2009, 23:02:10 »
Try the breakers on here mate - sure someone will be able to help - I got my replacement that way ;)
  • Auckland
    • Mazda MPV
« Reply #14 on: 10 November 2009, 23:13:06 »
I think people have posted on OOF that you can remove the ABS ECU and still drive the car.
Your brakes will still work but you won't have ABS/TC or a working speedo. (therefore not strictly legal)
I wonder if the speed display on a GPS would be accepted as a legal speedo? It would be more accurate in most cases........
