Author Topic: ABS & TC light coming on  (Read 5420 times)
cruisetopoland
  • UK
Re: ABS & TC light coming on
« Reply #15 on: 10 November 2009, 23:15:06 »
I think people have posted on OOF that you can remove the ABS ECU and still drive the car.
Your brakes will still work but you won't have ABS/TC or a working speedo. (therefore not strictly legal)
I wonder if the speed display on a GPS would be accepted as a legal speedo? It would be more accurate in most cases........
Except up or down hill  :y
amba
  • Medway towns
    • German V6
« Reply #16 on: 11 November 2009, 07:57:40 »
I drove mine with ECU removed and front of pump sealed over with ducktape....worked fine and only issue was no speedo(but that didn,t work with f..ed)ecu and no traction control or abs on the brakes.Power steering was fine ,actually felt better than with unit fitted as not speed related.
The garage that removed and refitted mine,did not need to use tech2 to blead brakes so only real issues were its removal and refitting ,which others have advised can be done by not removing the entire pump.
