Pages: 1 [2] 3  All   Go Down
Author Topic: Radio/Stereo Problem  (Read 7153 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio/Stereo Problem
« Reply #15 on: 13 November 2009, 16:19:56 »
Sorry!!!
Did it work ?   :-?
Radio & Decoding Technician
www.dndservices.co.uk
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #16 on: 13 November 2009, 16:25:05 »
Just got out of work and gave it a go tried both 2 + 5 and 3 +5, 3 + 5 stereo bleeped but diplay still blank??
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #17 on: 13 November 2009, 16:54:45 »
Only thing I can suggest next is to remove the radio for 10 mins, refit, and see what display prompts as far as code entry
Enter code, and then see what happens to the display then
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #18 on: 13 November 2009, 17:01:33 »
Ok I'll give that a try. I also thought of checking the pins on the plug at the rear of the unit.. the one that plugs into the metal cage what do you think?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #19 on: 13 November 2009, 17:12:09 »
Wasn`t that the first thing I suggested ?
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #20 on: 13 November 2009, 17:16:38 »
Sorry your right, I should have said the plug into the Display unit itself
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #21 on: 13 November 2009, 17:24:27 »
unlikely to be the display plug, but whilst out, check the wiring at the back of the stereo to make sure all is ok, and then let me know what it does when refitted
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #22 on: 13 November 2009, 17:25:25 »
Also, if you update your profile details with a location, there may even be someone nearby that can help you
  • Auckland
    • Mazda MPV
« Reply #23 on: 13 November 2009, 18:10:34 »
Errrrrrr I don't want to appear foolish but....
how does one enter the code if the display isn't working?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #24 on: 13 November 2009, 18:22:38 »
Fair question !
When the Vauxhall stereos are initially powered up, all display modes are run simultaneously so  that the code can be entered. Only once the code has been put in does the radio then default to  its programmed state.
If you have no display when first powered up, then you really do have a serious problem, and not a programming one.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #25 on: 13 November 2009, 18:55:25 »
Thanks for the help, I'll check it all out in the morning and let you know.
It's beer o'clock
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #26 on: 13 November 2009, 19:40:50 »
It's beer o'clock
How true  :D
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #27 on: 14 November 2009, 17:06:05 »
Hi again
Quick update, taken head unit out for 30 mins refitted, did'nt ask for any codes but original problem still persist. Checked both connections all seem ok so assuming it must be the headunit itself. Any how unless there are any other ideas thank for all your help up to now!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #28 on: 15 November 2009, 09:18:01 »
Hi again
Can you confirm that something is plugged into all THREE blocks and not just the lower two?
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #29 on: 15 November 2009, 10:21:17 »
I have to assume so, would the top pins not be bent if they wer'nt plugging together?
Pages: 1 [2] 3  All   Go Up
