Author Topic: Siemens NCDR 2011 Problem  (Read 7705 times)
Re: Siemens NCDR 2011 Problem
« Reply #15 on: 04 October 2009, 18:57:53 »
Sorry to be dim, but what is the cd module? Is that a part of the 2011 that can be replaced on it's own?
Colin
Yes, its the actual cd mechanism inside the stereo.  If its the same as the NCDC2013/5 top slot single cd drive, then they are available. Think VXL V6 found a good source.
nilocp
  • Halifax, West Yorkshire
« Reply #16 on: 03 November 2009, 09:58:42 »
I have just found a piece of paper in the radio manual that says ID No 938465316.
Would this be the pairing number?
Colin
« Reply #17 on: 03 November 2009, 10:18:24 »
Colin
If its like the other NCDR units, its double DIN in size, but its actually two single DIN units, with a double DIN facia. You can replace the cd module on its own...
« Last Edit: 03 November 2009, 10:19:58 by tunnie »
    • 530D M Sport, 330i Coupe
« Reply #18 on: 03 November 2009, 11:56:17 »
Colin
Nope, 2011 is a double DIN facia with a single DIN (NCDR1100) unit attached and no CDC ala 2013/15
Laser module available from limited sources for the single drive.
« Last Edit: 03 November 2009, 11:56:46 by VXL_V6 »
« Reply #19 on: 03 November 2009, 12:12:28 »
Colin
Ahh is like the CDR2005? Sorry know nothing about the 2011
bigmac
  • Devon
« Reply #20 on: 03 November 2009, 12:48:48 »
If you have a car pass look for immobiliser code ---> immob code: **** should be 4 digits this should be the code that they used to pair you HU & screen together the only time ive seen a stereo code is when its a CDR2005 or one that lets you enter the code manually and as the NCDC range are paired there wouldnt be a code just Immob code HTH
nilocp
« Reply #21 on: 05 November 2009, 20:36:52 »
Yes I have the immobiliser code. Does anyone else agree that this is the pairing code?
Colin
« Reply #22 on: 06 November 2009, 08:40:34 »
Colin
Yes it is unless the head unit / screen has been changed in the past and not remarried with the matching immobiliser (NCDC2011 not an option on UK spec Omega's only Vivaro's and Corsa's)
« Last Edit: 06 November 2009, 08:42:05 by VXL_V6 »
« Reply #23 on: 06 November 2009, 09:44:22 »
Colin
Its like your mum's ncdc2013, but without the cd changer. Never a standard option in Omega, and never offered as an option on UK spec ones. Not sure about Opel.
« Reply #24 on: 06 November 2009, 09:45:11 »
Colin
Only if the radio was factory fit.
bigmac
  • Devon
« Reply #25 on: 15 November 2009, 18:58:43 »
I might be able to get my hands on a NCDC2011 if your interested ?
Page created in 0.314 seconds with 20 queries.
