Author Topic: Display died  (Read 3486 times)
ViaraiX
  • Rochester, Kent
Display died
« on: 07 November 2009, 16:22:36 »
My display has suddenly died got in the other day and it just never came on and has been blank ever since (no backlights and no display at all)
fuses checked, all ok
is there any common issues?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Display died
« Reply #1 on: 07 November 2009, 17:08:21 »
Have you checked the Dash Dimmer, wiggle it up and down, they sometimes get noisy / intermitant if left on full brightness.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Display died
« Reply #2 on: 08 November 2009, 23:26:36 »
bulbs gone,
zirk
  • Epping Forest
Re: Display died
« Reply #3 on: 09 November 2009, 14:28:06 »
bulbs gone,
All of them?
Re: Display died
« Reply #4 on: 09 November 2009, 17:43:27 »
does it matter if headlights on or off?
rustym95
Re: Display died
« Reply #5 on: 10 November 2009, 19:43:50 »
bulbs gone,
All of them?
the new one i have got if the bulb is out on the left top the others dont work.
ViaraiX
  • Rochester, Kent
Re: Display died
« Reply #6 on: 10 November 2009, 22:46:56 »
not bulbs, they were recently replaced as 1/2 had died.
there is nothing on screen at all, even with all bulbs dead should still be able to make it out slightly.
lights on or off dont make a difference, fiddled with dimmer again no difference.
took dash and unit out to check any obvious faults... nothing I can see, its just as if there is no power going to the unit.
does anyone know what pins supply power feed so i can shove multimeter on it?
zirk
  • Epping Forest
Re: Display died
« Reply #7 on: 11 November 2009, 11:28:02 »
Not sure about the Pin Outs but you could follow the track from the bulbs to the connecter (check -0v as well) fairly sure the MID Display doe's not get fed from the Dash though, both the MID and Dash lights get fed somehow from the Dimmer, so while youv'e got it apart might be worth poping the Dimmer out and checking with your meter there also.
Chris.
« Last Edit: 11 November 2009, 11:32:08 by zirk »
ViaraiX
  • Rochester, Kent
Re: Display died
« Reply #8 on: 13 November 2009, 23:49:57 »
doubt its dimmer as the dash lights still fine and dim/brighten ok its just info display thats dead
Re: Display died
« Reply #9 on: 14 November 2009, 09:21:57 »
Hmmm, wondering if it is a display failure. Post 98 ones are pretty robust though.
If you add your location to profile, nearby peeps may be willing to take a quick look? Certainly if you're near me, swing it by :y
zirk
  • Epping Forest
Re: Display died
« Reply #10 on: 14 November 2009, 16:55:51 »
Think I may have miss read this one, I was under the impression Dash lights and MID display was out. :-[
Specsavers?
ViaraiX
  • Rochester, Kent
Re: Display died
« Reply #11 on: 15 November 2009, 14:47:59 »
nah just the info display.
i'm in Rochester, Kent if anyone is nearby and can help, plenty of beer in the fridge
I_want_an_Omega
Re: Display died
« Reply #12 on: 19 November 2009, 22:05:12 »
As it happens - I have a spare known working display from a '98 2.5 V6 CD.  If you are interested PM me.
Cheers
