Author Topic: keyfob  (Read 4500 times)
footloose
  • swindon wiltshire
keyfob
« on: 21 November 2009, 15:31:39 »
HIya.
I bought a new keyfob as the old one was totaly broken.
The pads on the buttons were breaking away and one of the switches flew apart. I fitted the old blade etc after checking that the chip was still in place. I then tried to initialise the key in the ignition as per instructions in hains and handbook. No luck at all. >:(
Iam having to lock up using the key. Is it poss that the chip has lost its way? or some thing more sinister i wonder.
Can anybody help please. :)
Re: keyfob
« Reply #1 on: 21 November 2009, 15:57:25 »
what kind of system is it? IR? do you have a receiver next to the sunroof dial?
Martin_1962
Re: keyfob
« Reply #2 on: 21 November 2009, 16:24:39 »
You need to get the new one matched to the car using Tech2 - see TheBoy or any other forum Tech2 owner
Or you can get the original fob repaired for a tenner
Re: keyfob
« Reply #3 on: 21 November 2009, 16:34:38 »
Not if its IR, those can be synced without......
Martin_1962
Re: keyfob
« Reply #4 on: 21 November 2009, 16:46:11 »
Attached key so not IR
The IR ones were seperate fobs
Re: keyfob
« Reply #5 on: 21 November 2009, 16:58:48 »
Project estate i had, that had IR and was on the key, at least i think so, was about 2 years ago  ;D
Abiton
Re: keyfob
« Reply #6 on: 21 November 2009, 17:14:30 »
Yeah, the spare I bought recently to fix mine was IR fob integrated with key.  Innards are identical. March '99 date code.
Re: keyfob
« Reply #7 on: 21 November 2009, 17:16:51 »
GM ditched IR by 99, must be a pattern part?
Anywho, footloose -
1) If its IR (blob thing next to sunroof dial) make sure the new remote has working battery
2) If its not IR, you will need tech2 and a car pass to program it
Abiton
Re: keyfob
« Reply #8 on: 21 November 2009, 17:22:13 »
No, looks genuine, maybe a new replacement someone bought?  :-/
Re: keyfob
« Reply #9 on: 21 November 2009, 17:30:08 »
1998 mini-facelift none had IR, so not sure :-/
footloose
  • swindon wiltshire
Re: keyfob
« Reply #10 on: 21 November 2009, 21:05:44 »
Hi, the car is a 2000 facelift model and the fob is integral with the key, Maybe the key will have to be reprogrammed
I dont real know It did work ok till i put the new fob onto the key.
footloose
  • swindon wiltshire
Re: keyfob
« Reply #11 on: 21 November 2009, 21:10:53 »
Hi again just had a thought. can the fob be programmed using teck 2 if i send the key etc with the car pass to some one with a tech 2 or do's the car have to be there?
Re: keyfob
« Reply #12 on: 21 November 2009, 21:11:31 »
The new fob will have to be programmed to your car, you will need tech2 & the car pass, which has details of the car. Closest one to you is Brackley, drop TheBoy a PM, and check out his page for prices. Otherwise you will need to take it to a dealer.
Re: keyfob
« Reply #13 on: 21 November 2009, 21:12:23 »
Can't be done via post, the car must be present.
footloose
  • swindon wiltshire
Re: keyfob
« Reply #14 on: 21 November 2009, 21:22:37 »
Ok thanks to everyone Ithink it will have to be a dealer.
I'll find out the cost on monday.
As i only have one key how much do you reckon a new one would cost.?
