Author Topic: hi can anyone help with ccrt 700  (Read 5193 times)
gerry31
« on: 26 November 2009, 12:21:10 »
ccrt700 coding problems just says safe on display cannot get bleep to sound
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: hi can anyone help with ccrt 700
« Reply #1 on: 26 November 2009, 12:53:12 »
You have to switch your ignition on and radio off before following the radio code entry procedure
SAFE with no numbers means IGN is not on
Radio & Decoding Technician
www.dndservices.co.uk
gerry31
« Reply #2 on: 26 November 2009, 15:55:41 »
i have tried alway ign on ign off radio on or off still all i can get is radio safe
  • Auckland
    • Mazda MPV
« Reply #3 on: 26 November 2009, 16:05:21 »
Did you follow these instructions http://www.omegaowners.com/forum/YaBB.pl?num=1185223347 from the maintenance guide section?
gerry31
« Reply #4 on: 26 November 2009, 16:15:18 »
i have tried as per these instructions still no joy the code is correct as i bought this car from the first owner and has full docs ......... the radio ect worked perfectly untill the battery went flat due to being parked up ............its driving me mad
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
« Reply #5 on: 26 November 2009, 16:29:53 »
were in the country are you mate maybe somebody could pop round and give a hand ???? just update your profile
« Reply #6 on: 26 November 2009, 16:47:20 »
How many times have you tried ???
And did the thing EVER count down from SAFE 10, SAFE 9, SAFE 8   etc etc ????
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 26 November 2009, 17:53:11 »
what EXACTLY is the display saying ?
gerry31
« Reply #8 on: 26 November 2009, 23:37:31 »
hi everyone text on dash says radio safe and nothing else no attemps have been made as i cannot get to the point were the system bleeps im located near chesterfield if anyone can help as im now lokking for a lenght of rope and a nearby tree
  • Auckland
    • Mazda MPV
« Reply #9 on: 26 November 2009, 23:56:01 »
Don't do that! just listen to Dave and follow the instructions on his website http://www.dndservices.co.uk/vauxhall-ccrt700-bose-on-star.html
What works for me is
1. turn ignition on.
2. switch radio off
3. turn ignition off & take key out
4. press AS key (and keep it pressed)
5. Put key in and turn ignition on (still pressing AS key)
6. keep pressing AS key until the beep :y
7. enter code by pressing buttons 123&4 to change the four digits of the code.
8. When the correct code is showing on the display press and hold the AS key again until it beeps.
Job done  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 27 November 2009, 09:22:41 »
2. switch radio off
Job done  :y
Actually, the code entry instructions for the CCRT700 are not on my website
However, the above code entry is not entirely correct, and needs the following amendment to start it off
Code Entry as Follows:
Switch On Ignition (No Need To Start Engine)
Turn OFF stereo
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
OR - use telephone keypad to enter code
(thats the bit I am unsure of)
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
I suspect that with the message of RADIO SAFE that the unit may be codelocked from incorrect code entry atempts, and if this is the case, the ignition and radio must be left switched on for up to a continuous 2 hours to reset before another code entry attempt is permitted. Make sure you have a confirmed code number as you do not get infinate attempts with that model, and once all attempts have been used up, thats it - I cannot reset it.
« Last Edit: 27 November 2009, 09:23:44 by Dave_DND »
gerry31
« Reply #11 on: 28 November 2009, 13:00:02 »
wow great stuff we have music and cd and phone for information the code is entered using the phone key pad ie 8 on pad for 8 on code and so on dont try to input by pressing repeatedly as this will lock code again
