Author Topic: Dodgy idle  (Read 3359 times)
goonv6
Dodgy idle
« on: 04 December 2009, 20:50:01 »
I put a new engine in the car 4k ago. Its been running well but yesterday it developed an eratic idle. it'll idle normally then drop to almost nothing. Sometimes it picks up andother times it stalls. As I've replaced the DIS, EGR and ECU I'm thinking TPS. Is this a known fault?
Re: Dodgy idle
« Reply #1 on: 04 December 2009, 20:57:47 »
my mind reading protocol is offline today....
What engine?  ::)
« Last Edit: 04 December 2009, 20:58:03 by tunnie »
goonv6
Re: Dodgy idle
« Reply #2 on: 04 December 2009, 21:04:40 »
Apologies, it seems to have fallen off my sig. its a 1999 2.5v6 manual
Re: Dodgy idle
« Reply #3 on: 04 December 2009, 22:06:45 »
firstly do a paperclip test and get the codes, also give the ICV a darn good clean  :y
Re: Dodgy idle
« Reply #4 on: 04 December 2009, 22:07:17 »
oh, this is also in the wrong section  :)
Abiton
Re: Dodgy idle
« Reply #5 on: 04 December 2009, 22:19:40 »
TPS problems seem rare on Omega from what I've (not) seen on here.  I had one apart off our 2.0, and was quite impressed with the ruggedness/good design of the innards. Changing it for another made no difference to stalling problems.
As Tunnie suggests, ICV cloggage may be your problem, as may breather blockage (which was causing this fault on ours).  I'd also echo his advice to apply the paperclip as a first step.
goonv6
Re: Dodgy idle
« Reply #6 on: 05 December 2009, 01:12:12 »
Why didn't I think of that! Doh! I've got a spare kicking around as well! Many thanks. ;)
