Pages: 1 2 [3]  All   Go Down
Author Topic: entering cd code  (Read 8716 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: entering cd code
« Reply #30 on: 30 November 2009, 19:35:21 »
I think at this stage I would consider to remove the head unit and unplug the changer at the rear for 30 mins, then try again
Radio & Decoding Technician
www.dndservices.co.uk
hedgerley
  • Fife, Scotland
« Reply #31 on: 06 December 2009, 15:13:58 »
OK, a variation on the theme....
I have the CCR2006 installed but have a similar problem - "CDC SAFE" is displayed when I press the CD key. This message appears nowhere in the audio manual. I've tried the solution mentioned but no joy. Holding the CD key down then switching on gives no bleep. After a while it returns to the radio. The radio coding works fine. Any ideas for the CD player?
BTW, just checked the 'Car Pass' and there is no type/code listed for the CD Changer, only the radio. So even if I can get the unit to allow CD code entry, I guess I'm stuffed?
« Last Edit: 06 December 2009, 15:50:33 by hedgerley »
Ken T
  • Stockport
« Reply #32 on: 06 December 2009, 15:52:39 »
Is there not something about if you put in the wrong code 3 times, it locks out for 5, 10 or 20mins ?.
Ken
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #33 on: 06 December 2009, 16:05:55 »
CDC-SAFE is an error message which denotes a software failure of the CCR2006 - the changer does not actually have a code, even though it appears to be asking for one.
We can certainly fix that fault for you
http://www.dndservices.co.uk/product.php?productid=528&cat=0&page=1
 8-)
topsy
« Reply #34 on: 06 December 2009, 18:00:35 »
finally after many attemps managed to get radio to take cd code left ign on with radio on for 12 hours it then had code ----   but would not take code then switched radio off and held cd button and switched radio on held cd button till beep and hey presto it then took code in "normal" way.
Thanks to all for your valued help and suggestions
topsy
Pages: 1 2 [3]  All   Go Up
